speedo fast
installed new ring gear 3.73 and i used the math formula out of npd catalog to find the drive gear i needed i have used this before on my 69 camaro and it work great this time it did not i'm 15 mph fast my tires are 27 inch tall drive gear is 8 and the driven is 22 any help would be great do i need to go up or down thanks again
Re: speedo fast
i googled it once and got a company in la. that was able to send me the speedo gears for the tranny. they also did the math to get it right.
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
![]() Join Date: Jul 2004
Re: speedo fast
I ran your info through 2 different online calculators and got 22.2 something for a driven gear, sounds right to me. Maybe the inside drive gear has more than 8 teeth ? Try checking your odometer against the mile markers on a highway, odometer should be fast also.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#4 | |
Re: speedo fast
example 60 seconds marker to marker divide 60 into 3600 = 60 mph """""""""" 51 seconds marker to marker divide 51 into 3600 = 70.5 mph or if you have a gps it can calculate for you
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan Last edited by 72BLUZ; 03-12-2009 at 09:19 PM. |
