Keep On Keepin' On
Bolts/Nuts for motor stand & mounts
Can someone help me out...I need the correct bolts for the motor stand and mount for my SBC...What is the correct size bolt? Please excuse my ignorance
Thanks Clint
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Bolts/Nuts for motor stand & mounts
Mine were 3/8 by 16. ~1 1/4 inch long.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
You may already know this, but use only "Grade 8" bolts washers and nuts. They're made from hardened steel and can withstand a lot of force before they shear.
Watch out for your cornhole !
![]() Join Date: Jun 2003
You can get the grade 8 bolts, nuts, and washers from your local Tractor Supply very cheap. They sell all grade 8 hardware by the pound in bulk.
grade 8 not really needed dont believe they came from factory// never had any problems with hardware store stainless
go grade 8 that is a lot of weight hanging out there on 4 bolts
just about zero wheight load on the motor stand bolts the whole load is gravity holding it down those bolts merely hold it in place and any torsional forces from the engine are disapeted thru the rubber in the motor mounts
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-13-2009 at 02:35 PM. |
If you are mounting the engine on a engine stand go with the grade 8 hardware. If you are talking about it sitting in the truck then stainless is the way to go.
It's a catastrophic success.
![]() Join Date: Jan 2003
Measure your stand bracket mount and allow about 3/4"to1" of the 3/8 #8 course thread bolt to screw onto block.
its all about the +6 inches
grade 8 is overkill
there's hardly any aplication on your truck that needs 8, grade 5 will do fine. otherwise, sneakysnake is right, you have to measure the tube he circled on his photo. |
The oem's used grade 5 because thats the grade that it needed and it saved them money. For the cost differance (pennies) I would just buy grade 8
i was talking about the four bolts to mount a eng too a eng stand. I would not trust any thing but a grade 8
When you said engine stand, I thought you meant the stands the engine mounts bolt to. Either way, 3/8 by 16.
Fabricate till you "puke"
Grade 5 vs 8 comes up from time to time, & you will hear many opinions on the subject......but the FACT is that the engine mount bolts,engine stand bolts, & ALL of the suspension bolts (including the front crossmember) ARE in FACT grade 8 from the FACTORY
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#15 | |
