Old 03-14-2009, 10:09 AM   #1
Jet Engine Mechanic
Steering column question
Hello everyone. I've got a quick question.
I've got a '69 shortbed Chevy that I've been working on lately. I was in the middle of installing a new steering wheel when I noticed that the steering shaft inside the column can wiggle around. I can move it about an 1/8th of an inch in all directions. I was just wanting to know if any of you had the same problem with and what the fix would be. I was wondering if there is a bearing inside or something else that needs to be changed out. Thanks
Jet Engine Mechanic is offline   Reply With Quote
Old 03-14-2009, 10:18 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Steering column question
the non tilt columns are like that. they are a crappy design. I'll bet you'd be able to pull the wheel in towards you too if you tried.
I've personally never found the fix, my fix was always to swap it out for a tilt.
Old 03-14-2009, 11:08 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Yes, there's a bearing on top and one on the bottom of the column. Problem is they're a pain to tear down and repair.
I had to take mine apart on my 69 Chevy about 20 years ago to clean and lube it cause the grease was so caked up it had turned hard. Since yours is such a small amount, I wouldn't worry about it unless it's causing problems.
68gmsee is offline   Reply With Quote
