GM plug wires! Put them on the truck or use them to hang myself?
Ok i just put a motor from a 85 GMC in my 71 GMC. now I know there might be a little differance in wires for a points style ignition and an HEI, but not much. you would think after all these years GM could come up with plug wires that actualy fit. Instead you get wires that are to long, to short, and then wires that dont even belong in the kit. I have a rats nest of plug wires on this engine and dont like it one bit.
Does anyone out there know if you can buy a set of plug wires that fit. ![]() ![]() |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: GM plug wires! Put them on the truck or use them to hang myself?
are you buying wires that are specific to the 71 or to the 85? or neither?
I have always had better luck with buying "cut to fit" sets.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
its all about the +6 inches
if you have ram horn manifolds, and HEI, and want to route the wires under the manifolds (like stock) then you need the wire set ffor a 75 vette with a small block.
I just got a set of hei wires for a '78 truck with hei (that's the only way O'reilly's can find a part, making stuff up) and they don't fit right at all. All the msd stuff i've had works good. Plus they have cut to your own sizes kits.
'72 cheyenne super step, '05 long bed gmc |
I always use taylor wires and make them my self, 100% better than stock would ever be.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Trucks N Tranzams
I used these. The best plug wires I have ever had. They may seem a little pricey, but well worth the money.
http://www.jegs.com/i/Moroso/710/73602/10002/-1
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
i buy taylor wires and make them to fit where i want them to go
Most reputable wire companies will make a set to fit your application. For the best fit, you should spend some money on spark plug wire guides. I have even seen, and used zip ties, just keep them away from the exhaust manifolds and from areas where rubbing will cause a hole or cut in the wires. This isn't rocket science, just common sense. Just stay away from some of the Vette plug wires, as some of the Vettes ran them thru the engine mounts. That was to keep them away from the exhaust, but what a PIA to install
'72 GMC custom camper 350/350 |
Just go and buy a set of whatever brand you want cut to fit wires and make them fit. I usually buy MSD because of their low resistence.
do the cut to fit work good? I bought a set one time and I just messed it all up, I was a lot younger and didnt have near the patience I do now. maybe I'll give them another try.
I did buy the set for a 85. Thanks for everyones help so far.
