Old 03-16-2009, 07:42 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: proportioning valve question for disk conv
Originally Posted by SS68 View Post
one more question, on the bottom of the proportioning valve the line for the front brakes the fitting that goes in there is 1/8 and i can only fit a 1/8" line all the other lines are 1/4" is this the same on yall?
You need to buy a 3/16" male-to-1/4" female adapter to screw into the bottom of the porportioning valve. This will allow you to run a 1/4" line down to the "T" on the backside of the front crossmember.
I got mine at the local ACE Hardware store. They are specialty fittings. (Inverted flare adapters)
Keith
Convert to disc brakes.
