Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-17-2009, 09:18 AM   #1
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Changed my mind, I'll mount a screen with a cover plate on top, since heat rises. Should make good air flow
Finally got the correct M/C Booster unit, now to paint and mount.... again!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-17-2009, 09:27 AM   #2
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Yep, heat rises but just make sure to give it somewhere to rise from.
I.E. - holes in the bottom.
vtblazer is offline   Reply With Quote
Old 03-18-2009, 02:32 PM   #3
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just spoke to M&H Elec. Fab. and was told it is correct to hook the red and black wire together on the stud of the block(ASM-SPL JUNC) mounted on the pass. side fender. The fused black wire(4 amp), with a white tracer on opposite side of truck, is to power up Ampere Gauge. Now to clean it up and antiseize the post
Soooo, this is the rare situation where red and black go together...confusion solved, onward
Thanks for your help and time guys
SAFETY FIRST
AS usual, off topic
Jim
Old 03-19-2009, 03:39 PM   #4
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finally had the time to hang the correct rebuilt M/C Booster, I may have finally removed all of the PO's handywork...that only took about a month to fix the problem.
Before someone tells me my mounting nuts are loose, I'll tell you what happened. I bought 4 new locking nuts, I dropped one, and the garage ate it! So the bottom one that is on there is to remind me to get another one
I'll probably have the cover plate Cadium plated later on.
Also received my second set of utility seats from Low n' slow, his are in much better condition...Thank You Doug
SAFETY FIRST
AS usual, off topic
Jim
Old 03-20-2009, 08:50 AM   #5
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Also finished up the bottom of the SS brake lines this mornin'...gotta find the last bracket for MC/ Booster in the parts pile. That could take awhile.
Todo list is getting shorter for start up
SAFETY FIRST
AS usual, off topic
Jim
Old 03-20-2009, 10:30 AM   #6
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
Those lines look pretty nice...ever thought of becoming a plumber?
But seriously, things are looking great!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 03-20-2009, 04:24 PM   #7
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Sorry Tim, missed your reply. Can't accept credit for them, InLine Tube did all the work, and great people to deal with. Called them numerous times with questions and they were always helpful and friendly. Still have to buy the emergency brake cables
Thanks for the offer, but after 35 years of crawling around in grease in all sorts of temperatures I'm sticking with Pharmaceuticals ( Sterile and Aseptic)
SAFETY FIRST
AS usual, off topic
Jim
