73-87 Power booster Mod to fit our trucks ?
I don' have a original booter for a C10 and I don't like the way that the original one looks. So do you see any reason I could'nt use a newer one? I may have to make a longer push rod and drill/ fill some holes but no biggie. I am in the paint and body work process now so I can weld and drill all I want.
Thanks Mario ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I've got one from a newer truck (80's) and have been fitting it to the cab im working on. It's no big deal from what I can see. The bracket for the booster needs 2 additional holes drilled and I plan on cutting off the top portion of the bracket (the old 2 holes that aren't used). Then you'll need to make a longer push rod (about 3 inches longer I'm guessing).
Half a bubble off!
You guys might try a search, I seem to remember seeing some good info concerning this mod in the past. This is one of those topics that we need a good, informative, article on, and then have it included in the FAQ section.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
when you change booster and master cylinder what do you do with the purporsioning valve, did I spell that right
Out of the carpool lane.
Okay, it's been awhile since I had a '77 booster on mine, but I remember that I used a coupler nut to lengthen the rod and I had to drill 2 extra holes where it mounted to the firewall.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
or you can always do the next best thing which I will be doing, just take the brake pedal off of the 73 - UP truck and remove the old one from our trucks (67 - 72) and just put the proportioning valve in the same spot as the 73 - UP... I plan on going this route since I am going to be swapping front Suspension from my 74 C10 to my 68 (so I can get the newer motor mounts and disc front setup), and I am just going to use the newer brake booster and master cyl.. other then that should not be too tough...
1968 C10 Truck LWB Fleetside 1968 C10 Truck SWB Stepside 1994 K2500 Ext Cab Fleetside 2008 Honda Civic Si *lease* |
I plan on buying a Bare or Wildwood ADJ porp valve they look kinda trick I think. The old ones look GooFy. So you don't think there will be any problems Eh ?
