Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2009, 11:32 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
454 or something else?? 496??
Posted this in the general section but thought it might be better here since all of you deal with this stuff daily.
Bought the truck over a year ago and was told it was a 468 (bored 454) the current owner didnt know much more that that.
Found out by pulling the vavle covers early on that it has a set of Mid-Lift Roller Rockers along with a roller cam and lifter....... was pretty excited about that. Obviously could pull the pan without pulling the motor and everything was in to good of shape to do that................unitl now
Well below are some pics of what I found today.
MY QUESTIONS ARE AS FOLLOWS:
1. Is this a 454 or is it a 496 (probably dreaming or wishful thinking but follow me on this)
2.. I know they are H beam rods but I cannot find any part numbers to determine the length, from the center pin to the center of the cap they measure around 6 3/8'' (kind of hard to get an exact measurement) Why isn't there a part number? Is there a correct way to measure the length while in the block??
3. Crank?? Obviously an aftermarket but again can find no part numbers. Is it a 4'' stroke or a 4.25 stoke? How in the world can I tell without pulling the heads? Look how close the crankshaft is to the block? Can I tell if the crank is cast or forged by looking at the flywheel end?
4. The flywheel did not have a weight on it??? Should have for an externally balbnced 454. Maybe it is a forged crank that is internally balanced (probably wishful thinking again.
Help me out here guys this is driving me crazy.
Oh ya Bad news of today was the MSD distributor gear has 4 or 5 teeth that have worn to a knife like point What causes this?
MSD looks like it is corroded beyond belief, dont know how it even ran? What causes this?
And the las tbit of bad news/good news is the oil pump pickup was broke of and bairly hanging on?
I know this is long post but any help would be appriciated
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-15-2009, 10:35 AM   #2
Wild83C10
Wild83C10's Avatar
Re: 454 or something else?? 496??
CAn't halp you with the engine questions as I'm not familiar with BB. But you need to make sure you have a cam button with the roller cam and you also need a composite distributor gear.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-15-2009, 09:51 PM   #3
djracer
djracer's Avatar
It looks pretty good. You would need a dial indicator to measure the stroke and a dial bore gauge to measure the bore.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-17-2009, 08:07 AM   #4
6600DURAMAX
Well did some more investigating last night and was able to find some numbers on the front of the crank. They are DG3-454D............ When I put these into Google search I come up with a 4340 Forged Crankshaft with a 4.5'' stroke I am still not 100% sure because it looks like on there website they show there name above the number and, although very hard to see up in there, I do not see RPM anywhere on the crank. Could be something they just started doing recently also????? I will call them today and get there input.
RODS??? - They have numbers on the bottom of them but I cannaot get them to cross reference against anything. Each rod has a unique number.
8913S, 9023S, 8664S............ Any idea guys
Looks like it could be a 500+ cu in motor, which would mean the 427 heads taht are curently on there are the reason it doesnt act like it...... Or it could be that nasty distributor
Old 03-17-2009, 08:49 PM   #5
Malibu 496
Junior Member
Malibu 496's Avatar
Is the block clearenced? I cant tell by the pictures if it is.
When I built my 496 I had to clearence the bottom ofeach cyl for the additional stroke. Also I thought 4.25 stroke was the biggest stroke you could put in a stock block but I could be wrong.
1970 blazer, street/strip project
1963 ford fairlane sports coupe 50,000 original miles
Malibu 496 is offline   Reply With Quote
Old 03-18-2009, 08:27 AM   #6
6600DURAMAX
Mailbu, you could be correct, I am not sure what it would look like if it was clearenced though??? Dont have a standard block to compare to.
Talked to the guys at RPM yesterday and they say it is their crank sold under a different vendor since it did not have the RPM logo. GREAT Right???? WELL last night I just couldn't leave it alone that it still probably was to good to be true. So I attempeted to measure the stroke for myself without pulling the head. I did this by measuring how far the bottom of the piston shirt moved in the cylinder. I think this should give me the stroke CORRECT??? Well I came up with 4'' WTF ??? Looks like I just have a high dollar forged stock stroke cranks So I guess there are cranks out there with the same number as the RPM cranks that are NOT 4.5'' stroke?
I am really bummed but shouldn't have expected more than that I guess?
someone let me know if they think the way I measured was incorrect, maybe that will shine some light onto this day.
Old 03-18-2009, 10:08 AM   #7
Alex1
Alex1's Avatar
I don't think you can get a 4.5" crank in a factory 9.8" deck BBC.
I would pull a cap or two to make sure the bearings are good and put a new distributor gear on - or swap to another distributor completly. Also not all roller cams (solid or hydraulic) require a bronze or compsosite gear but you will have to figure out which one you need.
Someone also mentioned you need a cam button - yes you do because you have to limmit the cam movement so make sure you have that as well - also check the cam gear - it's probably damaged as well.
Alex1 is offline   Reply With Quote
Old 03-18-2009, 11:26 PM   #8
Ironclad454
Registered loser
Ironclad454's Avatar
Unless it's a 10.2" tall deck 427 block that someone pulled out of a medium duty and rebuilt. He did say it had 427 heads on it. Just an Idea.
-Nate-
There is no replacement for displacement
1996 Buick Riviera 3.8L S/C V6- DD
1973 Chevrolet Cheyenne Super C/10 LWB 454/TH350
Ironclad454 is offline   Reply With Quote
Old 03-19-2009, 08:23 AM   #9
6600DURAMAX
It does have a cam button. I believe it is just a standard height 454 block that someone put a stock stroke forged crank in. I am now trying to convince the better half that I NEED aluminum heads !!! If someone out there has a cheap set laying around let me know. hahaha
Old 03-19-2009, 03:39 PM   #10
djracer
djracer's Avatar
Look at the patriot performance heads they are pretty cheap!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
