03-18-2009, 02:25 PM | #1 |
One of the First
WTB K20 Brake Booster
Looking for a complete set up: K20 Power Brake Booster, all brackets, linkages. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-18-2009, 03:39 PM | #2 |
Member #1049
Re: WTB K20 Brake Booster
Which year are you looking for?..
I have 67-70 C-K/20 drum brake assemblies for $50 plus shipping.. Or 71-72 C-K/20 disc brake setups for $40 plus shipping.. |
03-18-2009, 07:21 PM | #3 |
"Trucks with Class"
I will soon have "NEW" ones that are not available anywhere else that I know of. These are NOT rebuilts. I have all the components mocked up & measured & will test run them on my trucks before selling. It should be a couple weeks.
Both 9" DD & 11" DD OEM style, not hotrod. Last edited by PICKMUP; 03-18-2009 at 07:23 PM. |
03-18-2009, 11:40 PM | #4 |
Is there a difference between the 2x4 and 4x4? If so, what?
03-19-2009, 06:28 AM | #5 |
One of the First
I posted on the fly , but I need the 71-72 set-up for DISC (prop valve) brakes. Could you post a pic of the one you have for sale?
03-19-2009, 10:38 AM | #6 |
One of the First
03-19-2009, 11:04 AM | #7 |
Member #1049
otsenre both the 2WD and 4X4 versions are the same,
67-72 1/2 ton Boosters and brackets only are the same.. Master cylinder, steel lines and combination valves are 67 - 70 only (drum brakes).. And 71- 72 only, proportioning valve, steel lines and master cylinder, (disc brakes) 67-70 3/4 tons are the same (the 67-70 3/4 ton small dia dual diaphram will work with the 1/2 tons disc brake setups. 71 - 72 3/4 tons are the same.. D.PASSMORE I will snap some pictures today at the shop and post them this eve.. |
03-19-2009, 11:23 AM | #8 |
Thanks, because I have one off a 72 c/30, and I have the one I need for my 72 4x4 (I hope)
03-19-2009, 11:53 PM | #9 |
Member #1049
Pics as promised..
03-20-2009, 06:27 AM | #10 |
One of the First
Looks good, send me payment instructions. Thanks
03-20-2009, 12:22 PM | #11 |
Member #1049
