Old 03-13-2009, 04:53 PM   #1
Curly86
You want it there when???
Curly86's Avatar
Rough Running
I have an 86 SWB with a 75-80 model 400 SB in it. When i park it for 2-3 days it will miss and run rough for about 2 minutes and it will smooth out.But it is getting worse and I"m starting to lose some water and I have a feeling it is a blown head gasket and it will puff a little white smoke every once and a while. And I have a little water coming out of the tail pipe am I on the right path? any suggestions?
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 03-13-2009, 04:56 PM   #2
BusinessProfessor
Re: Rough Running
Yes, it sounds as if you are on the right track!!! Good luck!
BusinessProfessor is offline   Reply With Quote
Old 03-13-2009, 05:01 PM   #3
Curly86
Curly86's Avatar
Re: Rough Running
That was what I was thinking
TNCTC
Streetcruzin
Old 03-13-2009, 07:46 PM   #4
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: Rough Running
Check your plugs, they will tell you if you're getting water in a cyl, but you
might find that one is oil fouled and doesn't fire til it is hot.
Any manual will have the "sparkplugs with different problems" picture.
heavychevy79 is offline   Reply With Quote
Old 03-13-2009, 10:06 PM   #5
Curly86
Curly86's Avatar
Re: Rough Running
Ok Thanks I think it is on the right side I am goin to change the plugs tommorrow
TNCTC
Streetcruzin
Old 03-14-2009, 12:37 AM   #6
heavychevy79
Cheyenne Super
Re: Rough Running
But make a note of which plug came out of what hole, just in case.
Old 03-15-2009, 08:26 AM   #7
Curly86
Curly86's Avatar
Re: Rough Running
ok thanks guys
TNCTC
Streetcruzin
Old 03-15-2009, 08:44 AM   #8
grinch4om
dang its hot
grinch4om's Avatar
Re: Rough Running
400's are notorious for head gasket failures. siamese bore holes, steam port holes between cylinders. Pay attention to the gasket when you tear down and where it has failed, check that head and the block for metal erosion
grinch4om is offline   Reply With Quote
Old 03-21-2009, 09:03 AM   #9
Curly86
Curly86's Avatar
Re: Rough Running
ok will do thanks
TNCTC
Streetcruzin
