Old 03-22-2009, 12:58 AM   #1
sailed2japan
Jonny
sailed2japan's Avatar
And so it begins 64 Crewcab SWB Build w/ Cummins Power
So, I've done it again. I've got way too dep into my ambition. It all started when I got a pm from padresag about a pair of doors and frames from a Stagecoach Conversions truck. Then it got emphasized when I found a 64 big window SWB for $400 on craigslist. Now I'm building my dream truck. Unfortunately I think the build will turn into a nighmare. However, here's the build plan:
Drivetrain:
Cummins 4bt
Holset HY35W Turbo
+40hp injectors
Modded injection pump
Power at about 200hp/450ft.lb
Dodge NV4500 5 speed manual w/ od
Dana 60 w/ 3.54 posi
Body/frame:
Front of 64 small window cab
Stageway rear doors and frames
Back of big window cab
short wide bed
60-61 or 63 grill
frame will be built out of 2 frames. The front half of one will be cut behind the cab and the other will be cut behind the cab. The two "halves" will be joined using a tongue and grove type joint and then boxed.
Other:
first will be built w/ drop spindles and 4" rear drop coils, eventualy I'l be able to afford air ride, then it'll be as low as it will go W/o notching (I just don't like Notches)
8 lugs all around
83 front discs
thick front sway bar
Soo what do you all think?
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 03-22-2009, 01:05 AM   #2
sailed2japan
Jonny
Re: And so it begins 64 Crewcab SWB Build w/ Cummins Power
More Pics:
-AEC Hundley USNR
Old 03-22-2009, 01:08 AM   #3
joe231
joe231's Avatar
Drivetrain:
Cummins 4bt
Holset HY35W Turbo
+40hp injectors
Body/frame:
short wide bed
60-61 or 63 grill
Other:
8 lugs all around
83 front discs
guessing this is a typo??
wouldn't accomplish anything
sounds very cool
I can't wait for progress
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-22-2009, 01:11 AM   #4
Captainfab
60-66 Nut
Sounds like you've got a plan
And looks like you have enough parts too. Having the Stageway doors and frames should take a lot of the headache out of it. Keep us up to date with pics
Old 03-22-2009, 01:19 AM   #5
justcuz
justcuz's Avatar
From the look of the fender in back this one was a Suburban. All 4 doors will function on this build then correct? You figure the diesel has the torque to deliver the motive power with 3.54 gears plus od in the transmission?
justcuz is offline   Reply With Quote
Old 03-22-2009, 10:29 AM   #6
padresag
[QUOTE=justcuz;3211498]From the look of the fender in back this one was a Suburban. All 4 doors will function on this build then correct? You figure the diesel has the torque to deliver the motive power with 3.54 gears plus od in the transmission?[/QUOTE
they were out of an ambulance
ron
padresag is offline   Reply With Quote
Old 03-22-2009, 10:45 AM   #7
YOLO
Custom Truck Lover!
YOLO's Avatar
good luck. keep us posted with progress pics
YOLO is offline   Reply With Quote
Old 03-22-2009, 01:01 PM   #8
sailed2japan
Jonny
sounds very cool
OOPS!
One behind, One in front.......Drunk posting, it happens
-AEC Hundley USNR
Old 03-22-2009, 01:13 PM   #9
sailed2japan
Jonny
All 4 doors will function, I may also put in some one peice windows. The 4bt will have plenty of torque for the gear set and od. I actually chose to use the D60 for the available gears.
NV4500 gear ratios:
First Gear 5.61
Second Gear 3.04
Third Gear 1.67
Fourth Gear 1.00
Fifth Gear 0.73
Reverse 5.04
So with the low first gear the 3.54 gears are a good match. Plus for optimum efficiency on the highway I want to be at about 1800-2100 rpm.
-AEC Hundley USNR
Old 03-22-2009, 01:26 PM   #10
protrash64
Resistance is Futile
protrash64's Avatar
Thumbs up Re: And so it begins 64 Crewcab SWB Build w/ Cummins Power
Sounds cool to me!!!! Cant wait to see what it all looks like. Sounds like you better stock up on some sawzall blades.....post some pics as you make progress.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-22-2009, 04:27 PM   #11
64c20crewcab
64c20crewcab's Avatar
Dude, Sounz way kewl! Good luck with this!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 03-22-2009, 04:41 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
OMG... this is going to be sick!
Best of luck on the build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-22-2009, 06:23 PM   #13
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Can't wait to see this project get off the ground. Crew Cabs old and new are the hot trend for this era.
66Gilbert is offline   Reply With Quote
Old 03-22-2009, 06:44 PM   #14
Dinos63
chevy only
Dinos63's Avatar
killer !you got plenty of parts and looks like a nice big window s/b get rockin dude!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-22-2009, 08:22 PM   #15
sailed2japan
Jonny
Thanks for all the encouragement guys. I can't wait to get this thing together. I've always had a thing for doing something different. I think I've found it in this build. I'm also stretching the limits of my abilities. I have never doen anything even close to this. Don't get me wrong, I bought my first car (73 Valiant) in a junkyard, worked on it for a weekend and drove it home sunday night, so I can fix thngs. However, I've never built a frame, or a cab, or done alot of body work, but I guess there's always got to be a first time!
Now I think my plan of attack is going to be to build the cab first and then build the frame so that the cab fits on it. Any suggestions?
-AEC Hundley USNR
Old 03-23-2009, 12:19 AM   #16
Captainfab
60-66 Nut
That sounds like a good idea....cab first. Since you've never built a frame or much body work, have you done much welding before? Welding frames are a lot different than sheetmetal. Not to discourage you, but if you aren't totally sure of your welding abilities on a frame, don't be afraid to seek a little help from a professional. It would suck to have a frame come apart going down the road. If I was closer I would give you a hand.
Old 03-23-2009, 11:20 PM   #17
sailed2japan
Jonny
I've doen stick and mig welding on the thick stuck, the sheet metal worries me more. I just need to buy my own welder and do some practice on all the trash I have hanging around...like the cats....
-AEC Hundley USNR
Old 03-23-2009, 11:24 PM   #18
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Sounds cool man...way cooler than the Burban blowing smoke idear !!
That'll be sick.....GET ON IT !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-24-2009, 12:28 AM   #19
Captainfab
60-66 Nut
When it comes to welding sheet metal I like to use .023-.024 wire but .030 works good too. If you try using .035 you might have some difficulties. When welding sheetmetal do a series of tacks and skip around. It takes a while that way, but in the end it's less than trying to straighten out all the warpage from too much heat.
Old 03-24-2009, 07:45 PM   #20
sailed2japan
Jonny
Thanks for the advice, captianfab, I need all the help I can get!
-AEC Hundley USNR
Old 03-25-2009, 12:48 AM   #21
Captainfab
60-66 Nut
Anytime
Old 03-25-2009, 09:01 AM   #22
sailed2japan
Jonny
So, I was looking over my pics of the doors last night and contemplating ideas, when I realized that it looks like the doors I am using to put this thing together are longer than those on dino's and 64crewcab20's rigs. The difference is that these doors are the same length as the front doors and have a squared off dummy front window. Where as the doors on their trucks are cut down and only use a standard door window. I also noticed it looks like the hinges will be insidethe body, instead of popping out the side.
-AEC Hundley USNR
Old 03-25-2009, 09:53 AM   #23
joe231
joe231's Avatar
YOUR CATS CAN WELD!!!
CHEVY ONLY
Old 03-25-2009, 11:22 PM   #24
sailed2japan
Jonny
No, but they can be welded!
-AEC Hundley USNR
Old 03-25-2009, 11:32 PM   #25
66Z71
66Z71's Avatar
kewl. I wanna see this one done. You have a huge headstart on ghe crewcab part. Do you have any pics of the inside of the sides, or any that show just how they reworked the doors. Where did they cut, how did they piece it together?
Eric
66Z71 is offline   Reply With Quote
