Jamie Hyneman is my twin
![]() Join Date: Nov 2005
No fuel from fuel pump. Help
The only thing worse than being stranded with fuel problems is being stranded while trying to sell a truck. The buyer was on a test drive. I was so embarrassed.
This happened last time I had the truck out, so I replaced the fuel pump, and put a clear fuel filter between the filter and and the carb. The truck hasn't been driven regularly in 3 or 4 years, so I think that there may be gunk in the fuel tank clogging the fuel pump. What should I do?
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
What?
Re: No fuel from fuel pump. Help
Did you check the usuall suspects?
Fuel tank sock? Some carbs have a filter built in right at the inlet. Goin deeper... is the cam old? Chevy V8's (assuming you have a V8) fuel pumps are actuated by a lobe on the front of the cam shaft.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
The Older Generation
Does it start back up after it sits for a while? I think I would pull the sending unit out and make sure the sock filter is still on the end of the pickup tube and that it isn't clogged. It sounds like something may be sucking into the end of the pickup tube and blocking the fuel flow... LockDoc
I haven't checked the sock, but I have checked and replaced the fuel filter in the carb.
It will fire a couple of cylinders after it sits, but it won't run. If the sock is clogged, and I need to flush the tank, what do I use, and how do I do it?
Weldin' it up
I had a problem with the sock cloggin up, i just cut it off, i have 2 other fuel filters any way. Check the sock just to be sure, its the last thing i thought it would be when i had the problem
-Paul- RIP El Jay Dirt is for Racing, Asphalt is for Getting There If need be, send me an e-mail at cbm_racing_90@hotmail.com ![]() 1970 Custom/10 LWB 4X4 350/TH350 ![]() 2003 Silverado 1500 Ext. cab ![]() 1974 Kawasaki 175 F7 Enduro ![]() 2002 Polaris Edge X 700 ![]() Last edited by 1970 chev truck; 03-22-2009 at 09:38 PM. |
Gone to greener pastures
![]() Join Date: May 2007
Are you getting fuel to the pump?
How about the rubber parts of the fuel line between the tank & the pump. Are they soft & collapsing, not allowing fuel flow? If you are still running the clear plastic, or glass fuel filter, I'd suggest ditching it. We've never met, but I'm willing to bet big $'s that you'll be really pi$$ed if the fuel filter either melted or broke and you had to watch your truck burn to the ground.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 03-22-2009 at 09:40 PM. |
#7 | |
LockDoc
I'll pull the tank tomorrow and get a new sock and some heat. When I replaced the fuel pump, I had gas coming down the line. I haven't checked rubber lines, but I have some fuel line, and It won't be hard to replace.
El Jay - You are right, I don't want to watch it all go down in flames. But, with a metal filter, I couldn't tell if I was getting fuel to the carb while working on the truck by myself.
Have you checked the fuel line leaving the fuel pump to the carburetor? Recently, my truck died while driving it. I could not figure out why I wasn't getting fuel to the carb. When I looked down, what looked like a radiator hose leak, turned out to be the fuel line leaking. The fuel line was falling apart, from what seemed to be a chemical reaction. It may have been from gasoline with ethanol. I replaced the fuel line and the problem was solved.
The other item to check would be the fuel sending unit. I replaced mine as it was plugged up, after years of sitting. Good luck.
'72 GMC custom camper 350/350 |
#10 | |
If you have a Chevy dealer near you the part # for the filter is 5651705. LockDoc
Nothing to see here.....
![]() Join Date: Jun 2007
second the METAL inline filters. heard too many stories about the plastic see-though type popping and, well let's just say total loss.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
