Old 03-20-2009, 08:58 AM   #1
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
My long term 57 project
I recently found this forum and have enjoyed reading about your projects. So I thought I would share mine. I bought my 57 Big Window Short Bed in Jan 1993 in Oklahoma City. I was completing pilot training for the Air Force and ran across an ad for it in the auto trader. I drove it back to SC pulling a Jeep CJ-7 with its long block in the bed!
Well, I got stationed in Panama South America for 3 years before getting to Charleston, SC. It sat another 3 years before I got the time to get started on it!
The first thing I did was remove the front sheet metal to get to the 428? Caddy motor and trans. My uncle gave me a Camaro clip and I hauled it down to Lawrenceville, Ga to have Mike Chesser weld it in. From the trucks I've seen clipped he does the best job of making it look like a factory install.
ChuckDriver is offline   Reply With Quote
Old 03-20-2009, 09:07 AM   #2
ChuckDriver
Re: My long term 57 project
After getting it home I pulled the motor and trans from my Grandfathers 71 Impala. It was a good runing 350/300HP and 350 trans combo and my Mom gave it to me. My Dad and I made a trans crossmember after one I had seen in a Classis Trucks article. I think we went a little over board, but it sure is strong!
JJ
Old 03-22-2009, 12:39 PM   #3
ChuckDriver
I completly rebuilt the front suspension with all new components, poly bushings and powdercoated the A-Frames and springs and spindles.
Old 03-22-2009, 12:43 PM   #4
ChuckDriver
The engine was in and out a few times before I did a "Krylon" rebuild. I just planned to use it for fitment and to build around it, but I got carried away and fully dressed it out!
Old 03-22-2009, 01:06 PM   #5
GRIMSS
GRIMSS's Avatar
Looks good. You also worked over the cab, any more pics of it.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-22-2009, 02:14 PM   #6
1956cameo
1956cameo's Avatar
That is a sweet looking truck you are building. That guy really DOES know how to put a camaro clip in and make it look almost factory. That is the best camaro clip job I have ever seen!
You and I must have bought our trucks from the same person. My 56 cameo also has a 429 caddy motor that was installed by one of the previous owners.
1956cameo is offline   Reply With Quote
Old 03-22-2009, 03:13 PM   #7
JML55
JML55's Avatar
Welcome, very nice work.
JML55 is offline   Reply With Quote
Old 03-22-2009, 06:34 PM   #8
ChuckDriver
Thanks JML55, your work is very impressive!!
JJ
Old 03-22-2009, 06:39 PM   #9
ChuckDriver
GRMSS
I have done a lot of work on the cab, I'll put up more pics soon! Thanks, JJ
Old 03-23-2009, 09:48 AM   #10
ChuckDriver
I bought a mig to do the welding on the cab myself. I had never done any before but thought this would be a great way to learn! There were A LOT of holes to fill including a very large one from the PO who put the Caddy motor in it. They had just covered it using the famous license plate trick! So I cut a section form one that had been rolled. I cut a larger section from mine to make it easier to line up, using as many flat areas and straight cuts as I could. There's probably a 1000 tacks to hold it in place!!
JJ
Old 03-23-2009, 11:14 AM   #11
stan3018
welcome >>>>nice work keep it up...
stan3018 is offline   Reply With Quote
Old 03-24-2009, 12:35 AM   #12
ezekiel
I would love to see a technical write up on that camaro clip installation.
That really is the Best Job I've ever seen on a clip installation.
Is there any chance that we could see some more in depth photos of that front clip?
Maybe even a tutorial on how to install it like that?
ezekiel is offline   Reply With Quote
Old 03-24-2009, 10:46 AM   #13
Kim57
Kim57's Avatar
Nice work JJ. Keep the pics coming, we love pics.
Kim
Kim57 is offline   Reply With Quote
Old 03-25-2009, 08:08 PM   #14
ChuckDriver
Ezekiel, I didn't do the clip. It was done for me by Mike Chesser in GA. He did a great job making it look like it grew there. I can supply a few more pic's, but I can't take credit for it. I'm sure if you contact Mike he would love to do a story on it. He has a web site showing a lot of his work.
JJ
Thanks Kim, I'll get more out there!
Old 03-25-2009, 08:18 PM   #15
ChuckDriver
Here are a few pic's of the rear suspension. I want to run a wider tire and rim than stock and keep them tucked under the fenders. I saw an article in Classic Trucks a few years ago for a mono-leaf kit that I think fits the bill perfectly. It's been so long ago when I bought it that I don't remember who I bought it from. I do have nearly 10 years worth of magazines that I would have to look through to find the article. Maybe someone here will recognize it!
It was very easy to install and came with everything needed to put it in.
The rear is from a 69 chevy car and it's a 12 bolt. I've since had it shortened by Moser who also added a 373 gear with a Tru-Trac Posi. It also now has Ford big bearing axle ends and faxles.
I also put a big brake kit on it from Master Power brakes. And ran SS brake lines.
Here are the pic's!!
JJ
Old 03-25-2009, 08:47 PM   #16
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Nice work...
Ken
87Lowrider is offline   Reply With Quote
Old 03-25-2009, 09:45 PM   #17
ezekiel
JJ
Is this Mike's webpage?
If so, I sent him an invitation to speak to his adoring fans
Old 03-26-2009, 03:46 AM   #18
ChuckDriver
That's the one. Sorry for not posting the link myself!
JJ
Old 03-26-2009, 05:12 AM   #19
OARNGESI
OARNGESI's Avatar
That looks good but why did you do the front and rear of the frame different colors
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-26-2009, 03:32 PM   #20
ChuckDriver
OARNGESI, You've got a sharp eye! It is two different colors. I primed the entire frame using Rustolem that I brushed on, then I painted the rear half and re-installed the rear suspension. It was a few months before I got to the front and I didn't like to color on the rear, to light, so I went a shade darker on the front. I used duplicolor and Plastic Kote spray paint, because I plan to blow it all apart sandblast the frame and paint it one color with a quality epoxy paint or maybe powder coat!
JJ
Old 03-29-2009, 04:05 PM   #21
ChuckDriver
Trying to upload more pic's, but they want re-size? Haven't had this problem before, is this an issue with the site?
Old 03-30-2009, 12:38 AM   #22
OrrieG
OrrieG's Avatar
I thought it automatically resized them when you use the "manage attachments" link. If not most editing programs have a resize feature with an "internet" option that sizes them for web pages.
Old 03-31-2009, 01:21 AM   #23
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job!!
CAL 58 GMC is offline   Reply With Quote
Old 04-01-2009, 02:37 AM   #24
nuke1
nuke1's Avatar
Great job on the truck so far, too bad it had to sit for 3 years, imagine what would have been done, it looks like you have the same brackets and pulleys on your engine as i do, from Bills hot rod company, nice stuff.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-01-2009, 09:23 AM   #25
ChuckDriver
Thanks nuke1!
Yes the three years it sat did slow down the process but i'ts been worth it. I really enjoy working on it when I get the time between work and family.
The pulley's actually came from Summit and the brackets are from Alan Grove. The brackets fit perfect!! I need to get going of the AC and I'll be ordering the brackets from him as well.
I've been trying to add more pic's but they want resize for me and I have no idea how to do it myself.
