and a few others
lifting the cab off the frame by hand
anyone done it....Just two men? No equipment. A cab, no doors, no glass, no steering column. stripped?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Dr. Frankenstein
Re: lifting the cab off the frame by hand
good luck....we put something like 2x6's thru were the windows should be and lifted with 4 people and it came about a foot of the ground and that was it.Alot heavier then they seem for sure
I Wanna Go Fast!! |
Certified Car Nut
I have a 55 Chevy Truck and me and a friend took mine of the frame. We put a 2 by 4 through the door and he on one side and me on the other and walked it right off the frame it was not that heavy.
2 of us did it with a '70 cab no problem. Just some gloves and lifted it by the rockers
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker ![]() |
Dr. Frankenstein
jesus how big are you guys? ok maybe using 18 and 19yr olds wasent the best idea but most of us are still above 6ft and 180-190lbs....hell im 6'4(you guys must be vikings or something)
I Wanna Go Fast!! |
Hollister Road Co.
This may sound a bit odd but I took one off by my self. I un-did the bolts then jacked up the cab over the height of the tires and rolled the frame out from under the cab. I just had to do some rearranging of the blocks to get past the wheels when it got that far.
I have since made a support beam for my engine lift to take cabs off. Last edited by dwcsr; 02-11-2009 at 07:10 PM. |
4 is the safest method. that way you can yell at someone other than yourself for dropping it!
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
I've slid a couple of cabs off by myself by lifting it up enough to slip a couple of long planks under it and then sliding it off to the side. I have even transferred one cab from one chassis to another this way by myself once.
and a few others
I forgot to mention it's a 54. The guy I bought it off of said he and his buddy put it on the frame. I was telling him how I was gonna use a engine hoist to take it back off, when he told me about it. Really had no reason to lie. Just wondering if anyone else had done it.
joeys66pickup, what kind of truck were you lifting? (I'm kinda leaving you an out here so maybe you can tell everyone it was a Kenworth or a Peterbilt) ![]()
Certified Car Nut
Well I'm only 5 "7 but I'm strong as hell.lol
I have to do most of my work alone, JD came in handy for the lift
![]() If I had to do it by armstrong, I'd do it like dwcsr did..... I lifted an El Camino off frame like he explained, wasn't that difficult at all. Just caught your other post on using an engine puller, that works good too. I've used them with cables attached to the body, similar to what I show in the pic....the cable would get bolted to the fender bolt hole. Last edited by Caveman49; 02-11-2009 at 09:13 PM. |
Dr. Frankenstein
its a 59' cab....but it had alot of bondo! and door windows so that has to count for something
I Wanna Go Fast!! |
did it with two people on a 53... Handed some 2 x 4s through and then just picked it up...
I can't count the times that dad and I set on and off the cabs on our trucks during our builds. The cab is much easier, than a bed with the wood and tailgate on.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
#15 |
Registered Chevy Owner
I used the engine hoist the first time, and the second time by myself with 2 2x4's as a "ramp". that time sucked. i would suggest the engine hoist.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#16 |
we didnt care about the cab on my friends 49 because it sat for 37 years got trees fallen on the roof so we just pushed it off and drug it with a truck...sorry im no help
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#17 |
i use 4guys.....
#18 |
and a few others
We got it done a couple weeks ago. We brought it to the sandblaser where he removed the cab with a frontend loader to blast it (it was just strapped on the frame) then when we brought it home we set the cab right on my trailer. Then, me and my brother, one on each side with a landscape timber on each shoulder, walked it right off and set it on the dolly in the garage. Real easy.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 03-23-2009 at 12:54 PM. |
