Old 02-11-2009, 09:04 PM   #1
BCOWANWHEELS
ho72, drw, 4:10 and hop52 srw both complete
i have 3 complete rear axles for sale.
1st axle- ho72, dual rear wheels, 4.10 gears, open diff.
2nd axleS (2 ) -ho52, single rear wheel, from behind a automatic trans so i assume its a 4.10 also and most likely a open diff
125.00 EACH
bob in kingsport, tn.
423 384 8938
BOTH ARE COMPLETE STOCK AXLES STILL UNDER TRUCKS
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-11-2009, 02:28 PM   #2
BCOWANWHEELS
Re: ho72, drw, 4:10 and hop52 srw both complete
Ttt
Old 03-23-2009, 03:15 AM   #3
earl87gta
earl87gta's Avatar
Bob do you know if there is a difrence between the SW and DW hubs on the eatons I am wondering if I can put the DW hubs on the SW axle to make it wider like on the 14blt axles.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-23-2009, 12:27 PM   #4
BCOWANWHEELS
Srw hubs will make it the widest however the drw hubs will interchage but you need to change out the brake systems also. Drw brakes are bigger. I have both if you want to just come and look.
Bob
Old 03-23-2009, 12:31 PM   #5
earl87gta
earl87gta's Avatar
Ill try and stop by this week and take a look. I have disk brakes on mine so Im just trying to find a way to make it wider so I can run hummer H1 wheels and tires. I seen on the NC4x4 site you were going to buy the rest of the ones for sale over there did you ever go get them ?
Earl
Old 03-23-2009, 07:35 PM   #6
BCOWANWHEELS
Yes i,ve bought all he has had. I have a bunch of new hummer tires & wheels. Call before you come so i dont miss you ok ?
Bob
cell
423 384 8938
