Old 03-22-2009, 07:27 PM   #1
rddaves54
rddaves54's Avatar
Proportioning valve rebuild kit
Is there a Proportioning valve rebuild kit or how can I check it to see if it is working. I have it off now. I have replaced everything on the brake system but this. 72 chevy c/10 front disk Chief mechanic for my 54Belair, 64Corvair, 72 C/10Fleetside and 2002Tahoe.
John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me.
rddaves54 is offline   Reply With Quote
Old 03-22-2009, 08:22 PM   #2
Husker
Husker's Avatar
Re: Proportioning valve rebuild kit
I have cleaned one before with I think mineral spirits.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-24-2009, 06:52 AM   #3
rddaves54
rddaves54's Avatar
Is there anything to it? Do you just take it apart and clean it up or is there something to be careful about when taking it apart?
I ran rubbing alcohol and then brake fluid through it will that be good enough or does it have to be taken apart?
Old 03-24-2009, 10:51 AM   #4
Green Machine
Green Machine's Avatar
Don't use mineral spirits, it will ruin the rubber parts. We took 2 old ones apart to try to get one to work for our 71. Not much luck. Best to buy a new one, I know they are expensive, but when you need to use the brakes, that is not the time to find out you saved $80. It's bad when they don't go, but it's worse when they don't stop.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-24-2009, 06:34 PM   #5
Husker
Husker's Avatar
I took the nut off the one end If I remember right I amy have use Sea Foam Cleaner in spray can or Mineral spirits. Mine did not work well until after I cleaned it out. My brakes in My truck are GREAT. I did all of this when I swapped to disc
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 03-27-2009, 10:18 PM   #6
blazer72
Freedom isn't Free
blazer72's Avatar
I took mine all apart and cleaned it with bore brushes, pipe cleaners, and Q-tips - put it back together - never had another problem with my brakes
blazer72 is offline   Reply With Quote
Old 03-28-2009, 09:04 PM   #7
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I went to NAPA and Autozone and they both said they don't sell them.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-28-2009, 09:27 PM   #8
Green Machine
We got a new one from Classic parts of America. Guess they are more than I remembered.
http://www.classicparts.com/1971-72-...ctinfo/71-245/
Old 03-28-2009, 09:28 PM   #9
americanmusc1e
americanmusc1e's Avatar
is your brake warning light on
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-29-2009, 12:50 AM   #10
stope4
If you take it apart and it's clean inside, just clean it out with some brake cleaner. Take the old o'rings to a place that distributes o'rings in Columbia. Tell them what the service is for and get some new ones. Use a little brake fluid on the new o'rings, slip them on, put back together and you should be good to go. Make sure the warning light pin matches up with the groove in the valve. If not, your warning light will go on.
stope4 is offline   Reply With Quote
