03-23-2009, 11:34 PM | #1 |
wanna be 67
CPP tubular control arms AIRBAGS
I have a set of CPP UPPER tubular control arms for airbags (part # 6372TCA-LAB) that will fit 1963- 87 2wd trucks. They are brand new just bought them a month ago for $529.00 plus shipping of $50.00!!! I would like to get $475 shipped if I was to get paypal. Family car took a dump and need some cash so wife can get to work. Have many pictures to show if interested.
here is some info from the CPP website. CPP’s Tubular Control Arms are designed to provide full wheel travel and minimal friction. The upper control arms are made from 1-1/4” x .120” wall and the lower is 1-1/2” x .120 wall D.O.M. tubing and the pivot barrels are thick 1-1/2” .188” wall D.O.M. tubing to eliminate distortion from welding and hard use. The upper control arms allow for 5 degrees of caster. The lower arms provide increased ground clearance and allow the use of sway bars. They can be installed with either factory uppers and lowers, or as a full set. The bushings are made from self lubricating non-squeak patented plastic that will out last any rubber or urethane, and works at temperatures in excess of 400 degrees F. The Chrome-moly cross shafts and sleeves are zinc plated for lasting performance. The sleeves have an interlocking design that prevents the hardware from ever working loose. The pivots carry both forward and back loads (the original cross shaft pivot was designed to only carry a forward or back load, but not both). The control arm assemblies are a simple bolt-in installation with no modification required. They work with all factory and replacement power steering systems, and with or without O.E. bump stops. |
03-24-2009, 06:44 PM | #2 |
Re: CPP tubular control arms AIRBAGS
pics please
also what ball joints are installed (for what years?) Last edited by 68 short step; 03-24-2009 at 06:45 PM. |
