Old 03-23-2009, 06:56 PM   #26
jared78
jared78's Avatar
Re: whats 20" wheels ride like?
MIne is on a 255/45/18 in the front and a 295/40/20 in the back. that set up is pretty conservaive but rides great. suspension has a lot to do with it, if you wack the springs run stock shocks and 20" tires, guess what, it'll ride like crap. If you run a good spring and spindle combo, flip the rear and not just start taking springs out, you'll have a truck that rides good and looks good. Also don't let anyone tell you to drop air pressure to make the ride better. Todays low profile tires are meant to run at a higher pressure. I run toyo proxes st tires on mine and they ride better at 40 psi than they do at 30 psi. with the right suspension set up, even a a 35 or 40 series 20 will ride good. (and handle even better), I have driven trucks with that set up also. The ride isn't any different to me than my dad's truck with 245/50/17s on it. good luck!
jared78 is offline   Reply With Quote
Old 03-24-2009, 08:52 PM   #27
Albatrossian
Georgia Boy
Albatrossian's Avatar
You've got a pretty nice avatar, 87Lowrider.. that's a handsome man!
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 03-24-2009, 08:52 PM   #28
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
thanks!
87Lowrider is offline   Reply With Quote
Old 03-24-2009, 09:01 PM   #29
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Ken,You look ..................well.Old and Tired in need of a lota rest.My poor dog saw your avatar and run under the desk.Poor thing is scared to death
powerdriver 1958 is offline   Reply With Quote
Old 03-24-2009, 10:28 PM   #30
82ChevyC10
I'm running 275/45/20 on all four corners. Same size as Harley F150's...I've got a 3/4 drop with djm spindles/shackles/hangers...street performance beltech rear shocks and monroe fronts (belltechs were on backorder)...ride is great, handles well...front bottoms out slightly when hitting large bumps...but should clear up when I swap in the belltech shocks.
82ChevyC10 is offline   Reply With Quote
Old 03-24-2009, 10:53 PM   #31
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by powerdriver 1958 View Post
Ken,You look ..................well.Old and Tired in need of a lota rest....
Hey , wait a minute! I resemble that remark.
Oooh, you meant the other Ken....nevermind....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
