Old 03-15-2003, 11:42 AM   #1
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Are there different pitman arms for power steering boxes (2wd)?
I'm having trouble clearing the lower A arm with the inner ball joint due to the fact that I notched my crossmember 1.5". It would be nice just to change out the pitman arm to something with less of an offset. Thanks.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 03-15-2003, 09:51 PM   #2
70 Jimmy
70 Jimmy's Avatar
Anybody? A simple yes or no will do. Details would be great but...
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 03-15-2003, 10:03 PM   #3
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I was talking to the guy that I bought my last power steering box from about changing my manual box to a power steering box. He suggested also changing my pitman arm also as it had a differant angle to it. You might find a manual and a power steering arm and compare them. If I can find his card I will PM you with his phone number.
Good luck
oldiron is offline   Reply With Quote
Old 03-16-2003, 10:09 AM   #4
crazy longhorn
Fabricate till you "puke"
I dont think you will find a pitman for the power box with a different offset, unless somebody has an aftermarket version. you might talk with Turner enterprises, as they do notched crossmembers......maybe they have dealt with the problem. i had to take a look at my 69(it has a stock crossmember), but it does look like there could be interferance issues with the inner tierod, with a dropped crossmember. Are you using the 67-72 arms, or the 73 up style?
crazy longhorn is offline   Reply With Quote
Old 03-16-2003, 12:59 PM   #5
kaycee
kaycee's Avatar
HMMMM
Can't really say on the angle but I did notice that the splines were different 1 was smaller circumference than the other 1 I swapped out from manual 2 power on 69 2wd
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 03-16-2003, 01:14 PM   #6
70 Jimmy
70 Jimmy's Avatar
Thanks fellas. I was going through the LMC catalog and they only show one power steering pitman arm. That goes along with your post and what I've heard from others. I guess I'll have to slot the mounting holes so I can raise the box .25".
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
