![]() Join Date: Apr 2008
Late model motor mounts 2wd
Is anyone useing motor stands and mounts from a 73-87?What mods are needed?
Under Construction
Re: Late model motor mounts 2wd
I have seen and heard of ppl using 73 - 87 mounts. IIRC, you have to drill a couple of holes in the xmember, that is all i recall... BTTT for you, someone knows more than me about these.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I am using them. 73-87 style. They work great. I bolted the mounts to the engine first and then just set the engine and trans in the frame. Drilled some new holes and bolted her down.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Did you use the existing top holes?
