Old 03-26-2009, 04:41 PM   #1
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Re: Cracked Frame & Crossover Steering
I have an all steel passenger side steering arm, Im just thinking abount connecting it to the knuckle with more than the 4 studs. Burt, I borrowed a picture of yours to show what Im thinking. (I know its the wrong side, but you get the idea).
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 03-27-2009, 07:40 AM   #2
FormerMember
There are lots of folks on Pirate that have done that. If you can weld cast properly, go for it. They also do double shear steering links now.
After market knuckles made by Reid Racing use a fifth hole in the knuckle:
http://www.reidracing.biz/DANA60.php
I've never had one come off, if I lock tight them and do the preventative maintenance. I'll go with Reid knuckles when I break my stockers...
Frame cracking is common with the push pull type steering found on our stock 4x4 trucks. It's allot of force that causes bump steer. If the bolts on the frame loosen, it's more of a problem. As indicated, crossover steering can certainly help that, as does correct steering geometry. Most frame crack happen when the steering linkages bind.
Overall, what size tire are you running? What sort of wheeling do you do? Do you have a steering maintenance program?
FormerMember is offline   Reply With Quote
Old 03-27-2009, 03:30 PM   #3
johnnywagon
Oh, Im not confused or concerned about the how and the why this happened. I know why. Hell, its not even the 1st time. I wheel the crap out of my truck, thats what it for, it still drives me home from the ORV park every time....so far. (knock on wood) .
Just like everything 4x4, you break it, you fix it better and so on...
As far what kind of wheeling? I probably wheel it harder that most "full size-ers", but Im not some throttle jockey thrasher either. I respect my equiptment and know its limits and rarely go beyond them. Like I said its all for fun. Check out this video, you'll see what kind of wheeling I do. Theres some good shots of me about 2 minutes in. Thanks everyone for thier input! You guys all kick-ass.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 03-28-2009, 10:59 AM   #4
johnnywagon
Crossover's done.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 03-28-2009, 12:01 PM   #5
royo
royo's Avatar
Looking good
nickle and dime
royo is offline   Reply With Quote
Old 03-31-2009, 11:41 AM   #6
johnnywagon
Finished my core support brace and got her all back together!
~John
71 Blazer One Ton
59 Belair 2 Door
Old 03-31-2009, 12:19 PM   #7
Burt4x4
Burt4x4's Avatar
Lookin Good
??for you??
Did your rig come with any type of plate INSIDE of the frame were your steering box bolts up?
Mine did, it's rivited to the frame with factory rivits. That pic above I posted of my front axel you can see the thick plate on the inside of the frame were the box bots on.
Just curious..wondering if I need to keep an eye on my core support too????
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
