resident oilfield trash
idiot lights to gauges
I have a nice bezel with gauges. I want to put it in my truck. Is there any way I can run it with out changing my whole harness. If not and I plug it in will my gas guage at least work
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
its all about the +6 inches
Re: idiot lights to gauges
your fuel guage will burn up if you just go out and plug it in.
GMC Paul has a chart on his site, shows what wires to trim and cross to make it work. |
Under Construction
Does someone have a picture of the idiot lights cluster. i have no idea what they look like......
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Project '67 454
Great info, I plan on doing that swap as well and didn't know it would burn up the fuel gauge if not properly installed, Thanks
I am excited it can be done. I wanted a gauge dash pretty bad.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 03-25-2009 at 03:51 PM. |
As i've said in teh past... if you just slap it in, you'll get funny working inst lights, the turn signals will control a high beam and an inst light if I remember right, and the fuel guage will spin around and then go out in a puff of smoke.
Ask my old friend, he watched mine do this and he was literally laying in the dirt holdin his belly he was laughing so hard. I on the other hand, wanted to cry. Alcohol may have been involved. |
Under Construction
Thanks for the PIC.... Andy
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-25-2009 at 06:16 PM. |
#10 | |
sad part is... it is 100% real.
Very small flat head screw driver and just take one wire plug out at a time and switch them all around. ( As per GMC pauls wire chart)
You will need a new oil sensor and steel line for the oil gauge to work. I think the temp sensor is different too. (no chance to try mine out yet) A hose for the vacum line connected to the bottom of the carb Run a wire to the Dizzy for the tach. And a + - wire to power the tach. And you have to run wires for the Amp gauge to the Alt and Batt. Good idea to check all the bulbs too before you put it in. Be carefull around the plug when putting in and out of the truck. Good weekend project. Get a case of beer too.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Who's got steelies?
![]() Join Date: Feb 2006
It is a pretty easy mod. This is how I did my burb: I ran 2 new wires out to the bat and alt. for the ammeter, and just used a small screwdriver to swap all the others around. You'll want to cut and connect together the two green temp wires where they go to the ignition switch, otherwise your temp gauge will peg at hot every time you start the truck.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
