Old 01-18-2009, 10:52 AM   #1
willis0107
67lwb
willis0107's Avatar
Not bad for 1400
I say that because its in really good shape. Its a 1983 blazer with a 6.2L diesel NOT A CUCV
800 for the Blazer with non running engine
300 for used engine
30 for new glow plug relay
270 for fluids and other misc items
Not only does it look good for the year but there is very little that i need to do to it to make it a daily driver
willis0107 is offline   Reply With Quote
Old 01-18-2009, 11:47 AM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Not bad for 1400
very cool, that's almost exactly what I want, just a good clean K5 for a DD
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 01-18-2009, 08:30 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks cool..
tvblazer78 is offline   Reply With Quote
Old 01-18-2009, 10:51 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
son of a gun!
the 6.2 isn't diesel is it?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-19-2009, 12:08 AM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Originally Posted by willett View Post
son of a gun!
Sure is. 379 cid oil burner...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-19-2009, 01:08 AM   #6
68Timber
I know the pieces fit
68Timber's Avatar
My daughter is pestering me for a K5 since I've got my project going. Wish I could find a deal like that - nice score!
Old 01-19-2009, 08:11 AM   #7
willis0107
67lwb
willis0107's Avatar
[QUOTE=BRUISER;3094746]My daughter is pestering me for a K5 since I've got my project going. Wish I could find a deal like that - nice score![/
The real score is that the tires have less than 100 miles on them from the day the guy bought them .
Old 01-20-2009, 08:00 PM   #8
68Timber
68Timber's Avatar
Looks like it already has a 2 1/2" lift as well...
Old 01-21-2009, 10:16 AM   #9
willis0107
67lwb
willis0107's Avatar
The springs and everything look stock. It is a diesel model so it sits a little higher to start with.
Old 01-21-2009, 05:22 PM   #10
kevinr1970
Why do you say that? Not arguing or anything but I wasn't aware of the diesels being any different in that regard.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-21-2009, 06:58 PM   #11
willett
willett's Avatar
son of a gun!
dang, i didn't mean diesel........
what i was trying to say was it isn't turbo is it?
i guess i was partyin' too hard when i wrote that
Old 01-21-2009, 07:44 PM   #12
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Very nice!
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 01-21-2009, 07:50 PM   #13
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Needs something else though, what is it?
Hmm...
http://store.summitracing.com/partde...part=gbe-21002
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-22-2009, 09:50 AM   #14
willis0107
67lwb
willis0107's Avatar
Hmm...
Maybe after I get some money saved up. I would really like to get a good set of bumpers made and some more aggresive tires. Then have the 6.2 rebuilt and have a turbo put on at the same time./
Old 01-22-2009, 09:51 AM   #15
willis0107
67lwb
willis0107's Avatar
They have a heavier spring pack on them.
Old 03-28-2009, 07:47 AM   #16
willis0107
67lwb
willis0107's Avatar
Alright so I am at a hold with the Blazer trying to figure out what I should do. I put a used 6.2 in it and have it running again. However the wiring is all F_____ so it is always draining the batteries. The engine and transmission fight each other. ( engine has to run extreme RPM'S in order to shift) so I am thinking of pulling the engine and putting in a built 350, buying a painless wiring harness and putting in, rhino lining the entire inside (except for dash) and then put heavier axles under it. I am wanting to get a differnt transfer case if possible. should I put the money into this or should I sell and get something else.
Old 03-28-2009, 09:47 AM   #17
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sorry things are not working out.. If you got into the blazer at a $$ then yes keep it and keep working on it. But if you think it just going to be a money pit, you may want to move on. Good luck..
Old 03-28-2009, 01:17 PM   #18
factory2wdblazer's
factory2wdblazer's's Avatar
like you said , not bad for 1,400 buck's.....
factory2wdblazer's is offline   Reply With Quote
