fixed the muffler, now onto other noises
Hey guys,
I finally had a day where i could pull the truck out of the garage and accomplish a little something. I replaced the wire coat hanger with a real muffler hanger so the muffler wouldn't rest on the driveshaft anymore ![]() Anyways, the tranny does make hella noise. Some of it was the muffler on the driveshaft but otherwise yeah, it's still pretty noisy. It makes a light scraping noise in neutral while the engine is running until you push the clutch in. Once you go into gear it continues to make that noise. Thats the best way to describe it. It actually has really good power and nothing slips out of gear, it goes through all four gears, just makes this constant scraping noise. there could be more to it but thats all i have for now. still need to change the oil in it before i do anything else. Any thoughts? |
Re: fixed the muffler, now onto other noises
I would check the throw-out bearing in the transmission, as well as, the carrier bearing on the drive shaft, if you have one.
![]() Join Date: Nov 2006
sounds more like the pilot bushing.
Usually, T/O bearings make noise when the clutch is being depressed, but I could be wrong. |
throw out bearings are noisy when the clutch is released, quiet with the pedal depressed
chrome makes it go FASTER!
as per your last post on this topic-
Have you checked the fluid in your tranny yet? Checked differential fluid ? Checked driveshaft to make sure it's not hitting anything else? another far-out thought/ Are your tires/rims hitting anywhere? Keep us posted***
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
thank you guys, i will check all these. i've never worked on a four speed so i wasn't even sure where to start.
