Old 03-28-2009, 01:10 PM   #1
RED68SWB
RED68SWB's Avatar
Axle question
Hows it going everyone.
I got a problem with my rear drum brakes. They squeak like crazy. I got a 68 SWB with a 5x5 bolt pattern. When I pulled the wheels and drums off I noticed that the rear axle was about 3/4" longer on both sides than it was supposed to be, leaving my drums too far away from where they are supposed to sit. My pads are only making contact on about 75% of the drum. Its a 5 x 5 bolt pattern, so its not original. Does anyone know when chevy started with the 5x5 bolt pattern? Im just trying to see if any one has any idea what my course of action is. Im thinkin I need to replace the rear axle, or something along those lines.
Any advice would be greatly appreciated.
RED68SWB is offline   Reply With Quote
Old 03-28-2009, 01:32 PM   #2
Wrenchbender Ret
Re: Axle question
They went to the 5 hole in 71 at the same time putting on disc brakes. The axles were longer. There are special after market axles for that or you have to change the whole rear end.
Wrenchbender Ret is offline   Reply With Quote
Old 03-28-2009, 03:28 PM   #3
Green Machine
Green Machine's Avatar
Re: Axle question
The 67,68,69 and some 70 rears were narrower, Mid 70-72 got the wider housings, all were still 6 bolt. Looks like someone swapped in some wider 73 up 5 bolt axles to get the 5 bolt pattern. Would have worked just fine if they started with mid 70 to 72 housing. Anyway I don't think you are in big trouble, I am sure I read on this board somewhere that you can find a wider 5 bolt drum that will cure the problem.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-28-2009, 03:41 PM   #4
DA68
Re: Axle question
Sounds like you have 71 - 72 axles in your 67 - 70 housing.
I was planning on doing the same with my '68 untill I found a complete 72 rearend. I know there is a wider drum that will help offset this issue. Try the search function on the site here.
DA68 is offline   Reply With Quote
Old 03-28-2009, 03:59 PM   #5
RED68SWB
RED68SWB's Avatar
Re: Axle question
I found a 12 bolt rear end off of a 68 C10 for $100. Im probably just going to buy a 5X5 axle conversion kit from summit.
Thanks for the replies
Old 03-28-2009, 04:22 PM   #6
LONGHAIR
Re: Axle question
Yup, sounds like long axles in a short housing, but IMHO it is not as easy as running wider drums. The axle itself has a "bearing area" right behind the flange that is were the bearing is supposed to ride. Simply putting the long axle in the short housing moves this bearing area out away from the bearing, plus the fact that the axle was not intended to run with that much "extension" from the bearing.
Personally, I would purchase a set of conversion axles or at bare minimum have a set of six-luggers re-drilled.....of the correct length of course.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-28-2009, 06:09 PM   #7
Green Machine
Re: Axle question
Now might be the time to consider what else you are going to do brake and wheel wise. Chevy went to a wider rear axle in 71-72 because they went to disks on the front which give a wider track up front. If you put disks up front, then a wider rear would match better, or if you want to put wider rims on the back than front, sometimes the narrower rear is an advantage. Just something to consider.
Old 03-28-2009, 06:52 PM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Axle question
71 72 were 5 lug not six on half tons
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-28-2009, 06:55 PM   #9
jbristo67
jbristo67's Avatar
Re: Axle question
I bought my 5 lug rear for 150. The deals are out there you just have to hunt for them a little bit. There is a guy here locally that has a bunch of 5 lug rears that might not cost to much to grey hound them.
2011 Nissan Armada
Old 03-28-2009, 09:45 PM   #10
Green Machine
Re: Axle question
My bad - brain fart - that is the reason for using the newer axles to get the 5 bolt ! Engage brain - then type !!!
Old 03-28-2009, 11:07 PM   #11
westofb
I really hate wet sanding!
westofb's Avatar
Re: Axle question
I am not to sure this would work, but was just wondering if a person could make shims (and of course longer bolts) that would space out the backing plates, thus lining up your brake lining and drums better. Just a thought I had after reading your prob. Hmmm.... 3/4 inch would be one heck of a shim. Just thinking (typing) out loud.
westofb is offline   Reply With Quote
Old 03-29-2009, 03:13 AM   #12
jbristo67
jbristo67's Avatar
Re: Axle question
LOL I have that problem alot too
2011 Nissan Armada
Old 03-29-2009, 09:33 AM   #13
LONGHAIR
Re: Axle question
This does not solve the wheel bearing issue though.....
Old 03-29-2009, 11:57 AM   #14
Green Machine
Re: Axle question
Here is a link to a post that seems to report that the longer axles have room to run the wheel bearing in the "wrong" location, IDK, looks iffy to me. Longhair has a valid point about the bearings and that shaft sticking out too far, regardless of how it is done, putting the longer axles in a short housing, results in more bandaids to fix the problem.
http://67-72chevytrucks.com/vboard/s....php?p=2907045
Old 03-29-2009, 01:42 PM   #15
jbristo67
jbristo67's Avatar
Re: Axle question
Thats why instead of spending 400 on my 67 rear I put a 72 rear in it instead
2011 Nissan Armada
