Old 03-30-2009, 08:52 AM   #1
4oldcars
4oldcars's Avatar
Blower relay
I have a 72 sub (don't think it matters) and the blower won't run on high. I changed the motor, switch, and resistor. These were all parts that I had and it is possible that the part I put in had the same problem as the one I took out, but not likely. I'm told there is a relay but cannot find it. Anyone know where it is? Gotta be the relay.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 03-30-2009, 11:22 PM   #2
mosesburb
I had a V-8
mosesburb's Avatar
Re: Blower relay
Definitely sounds like the relay. Check on the right hand side of the heater box under the dash right by the kick panel. That is where mine is, but I do not recall if that is where it was originally or if I just happened to put it there.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 03-31-2009, 12:36 PM   #3
nightmare
nightmare's Avatar
Re: Blower relay
that's where it is from the factory, mosesburb. same goes for truck and blazer.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
