03-21-2009, 10:21 PM | #1 |
Cam Help
I have been reading up on camshafts and I keep seeing in the specs. Cam Lobe separation (ie 108 or all the way to 114) I can't find a awnser in my books.So what does it do to the operation or output of the engine? please can some one tell me.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
03-22-2009, 12:21 AM | #2 |
Re: Cam Help
A cam with a lower LSA is less streetable and likes more RPM. It will produce more HP and Torque in most cases but is less streetable. anything below 110 is generally not a real good street cam bc they dont like to idle.
03-22-2009, 07:43 AM | #3 | |
Re: Cam Help
Narrower LSA have a smaller powerband but will put up bigger peak and average numbers. If you want to read strictly on LSA then pick up the current issue of Chevy High Performance, very good article. If you are building a street motor then 110 is probably the best LSA, but call a cam manufacture and let them spec a cam for you. Cammotion is pretty much only a custom cam manufacture, great tech guys, you don't have to wait an hour to talk to someone either. The cams are reasonably priced too.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-22-2009, 11:23 AM | #4 |
Re: Cam Help
THANK YOU it's something good to know
03-22-2009, 11:45 PM | #5 | |
Re: Cam Help
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
03-25-2009, 01:33 AM | #6 |
Re: Cam Help
LSA = Lobe Seperation. A wider LSA equals less overlap if that is the only thing changed on the cam. More overlap tends to move the TQ band up in RPM making it seem like it has less TQ, but in reality it has pretty much the same it just moves it up in RPM. Since HP is derived from TQ*RPM/5252 moving the TQ up in RPM the motor makes more HP.
Now, a narrow LSA such as a 106 does not make it more or less streetable than a cam with an LSA of 114. It has to do with valve events and total duration of the cam, where you want you power ect. My first combo in my truck had a 223/228 @ .050 with a 106 intake center and a 106 LSA. I was running LS6 heads on it and I wanted to keep power band's rpm similar to a stock LS6 vette. Even though the cam was bigger duration wise it still peaked at a similar RPM to a stock LS6 cam but made a bit more power through out the curve. A wider LSA is also typically used with a N20 application as it will open the exhaust valve earlier to reduce pumping losses. There is a lot to a camshaft, no perfect duration, no perfect ICL or LSA. It's all compramises and a cam should be tailored for your wants.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 03-25-2009 at 01:34 AM. |
03-25-2009, 09:14 AM | #7 |
Re: Cam Help
So if I have this right a smaller lsa will give you your torque in a short rpm range kind of like a power band.I think got this now cheers
03-26-2009, 12:23 PM | #8 | |
Re: Cam Help
03-26-2009, 06:55 PM | #9 | |
Re: Cam Help
Not really.. This might be a true statement if you only want to wind the motor to say 6k. Generically speaking, if you can spin it to say 7,500 your TQ curve is still there it just shifted up in the RPM band. You may just have a lack of TQ off idle to say 3,500 rpm where you are "coming on the cam" So this is a example and by no means accurate but if: RPM ------ 112lsa --------------106lsa ------------TQ----HP------------TQ----HP 2250------100---43 2500------150---71 2750------200---105 3000------240---137-----------100----57 3250------275---170-----------150----93 3500------305---203-----------200----133 3750------340---243-----------240----171 4000------365---278-----------275----209 4250------385---312-----------305----247 4500------390---334-----------340----291 4750------400---362-----------365----330 5000------390---371-----------385----367 5250------385---385 ----------390----390 5500------365---382-----------400----419 5750------340---372-----------390----427 6000------305---348-----------385----440 6250------275---327-----------365----434 6500------240---297-----------340----421 6750------200---257-----------305----392 7000----------------------------275----367 7250----------------------------240----331 7500----------------------------200----286 See what happened when the TQ was simply moved above. That is a generic idea of what happens when you change LSA. With this being said both cams there are showing and average TQ of 297ftlbs in the RPM range I am showing. But the cam with th 112 LSA has and average HP of 263hp in its range and the one with the 106 LSA has an average of 305hp. The tighter LSA may require a bigger converter and steaper gears. Again, it has to do with total valve events and the total combo you are putting together. Intake design, carb design, header design, head design and flow, all play a roll in the performance of the motor. You should be specing a cam for your intended use, not because it has XYZ LSA. Why don't you tell us more about your vehicle and intended use. Give us as much info as possible: Specs on the motor Power adder or NA Specs on the trans/converter Rear tire/gear Intended use. Remember the good equation of garbage in = garbage out.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 03-26-2009 at 07:04 PM. |
03-27-2009, 10:27 AM | #10 |
Re: Cam Help
Super73 "Why don't you tell us more about your vehicle and intended use. Give us as much info as possible"
I'm in the build mode right now I have a 454 that I will have to bore out to I belive about 30 over because a seat faild and score a few cylinders. Now I did pick a cam LIFT in .510/ex .540 DURATION @50 in 211/ ex 230 LAC 112 IVO@-6.5 BTDC / EVO@47 BBDC IVC@37.5ABDC / EVC@3.0ATDC I would like to run a 9.5 compression ratio the heads I have are 781 the vales are IN 2.19 / EX1.88 I will now trying to fine out how to pick the right piston to give me that CR I think the heads are about 114 or 118cc but untill I can cc them and see ? they are at the machine shop now getting stainless steel valves. I did the math on the block to get the swept volume and the cylender volume and it worked out at 8.5 static compression. This motor is ya going in my truck for a fun toy. I would love to get about 400+ hp but from what I have read but what sold me on the cam was the torqu close to 500 lb-ft and the curve was big and flat. Does any one have a good way of to pick the right piston to get to my 9.5:1 goal ? and thanks to all
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 03-27-2009 at 10:28 AM. Reason: wanted to add a thanks |
03-27-2009, 05:23 PM | #11 |
Re: Cam Help
Based on the .050" valve events you listed, I think the cam you are listing is ground on a 112 intake center with a 112 lobe seperation. I don't see 9.5 static netting you 8.5 dynamic. How are you basing your DCR calculations? Off the .050 lift number or the .006 lift number?
In order to get a IVC point of 37.5 ABDC at .006 lift (seat timing which is where DCR is derived from) you would have to have: 211* with an ICL of 112 @ .006 215* with an ICL of 110 @ .006 219* with an ICL of 108 @ .006 223* with an ICL of 106 @ .006 227* with an ICL of 104 @ .006 I'm guessing you are basing you dynamic compression ratio off you .050" lift number and need to be basing it off you .006" lift number. Typical aggressive hyd cams have about 50-60* more duration at .006 than they do at .050. That being said: A cam with 211* of duration with an ICL of 112 with 50* more duration at the .006" mark would actually equate to 7.7 dynamic compression with 9.5 static. You would have to have 10.5 static to equal 8.5 dynamic. With a cam having 211* at .050 and 60* more for the .006 number on a 112ICL and a static of 9.5 your dynamic would be 7.4. You would need 10.9 static to equal 8.5 dynamic. Can you send a link to the MFG's web page with all the cam details?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 03-27-2009 at 07:13 PM. |
03-28-2009, 11:05 PM | #12 |
Re: Cam Help
I hope you can see this pic this is the formula I use from the book (Max Performace Chevy Rat Motors) it said toal chamber volume = the total swept volx% of cylinder vol divided by the gas type-1 sothe out come of this is to give you the cr that will work best for your cam
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 03-28-2009 at 11:06 PM. |
03-29-2009, 01:19 PM | #13 |
Re: Cam Help
The scan is way too small.
How did you figure your DCR based on your cam specs and SCR?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
03-29-2009, 02:05 PM | #14 |
Re: Cam Help
I was trying to fine the cr that the cam needed to work right now. I need to get the right combo of parts to make it all work. I have never got this detailed about putting a motor together and I want to do this one right and cover all the details.I have been reading all I can and trying to work out all the math.Its realy is a fun learning curve for me, I have never done math for fun untill now!
03-30-2009, 05:16 PM | #15 |
Re: Cam Help
Typically you want to choose valve events first based on what or how you want the motor to run, then build for max dynamic compression based on the fuel you will run. The fuel is the limit before predetonation becomes an issue. There is more too it than that like head chamber shape, head material, quench ect. But a generic rule of thumb is 8.5 DCR is about the max you can run on pump gas.
With that being said, I was trying to help you work that backwards based on our camshafts intake valve closing point but you only provided .050" numbers not .006" numbers. You are not starting to build compression until the valve is fully closed. Since the intake valve is closing after bottom dead center, the later it closes the less DCR you have. You are almost always going to make more TQ and HP with more dynamic compression. You mined as well max it out at the 8.5 DCR. The cam you were looking at going with, can you provide a link to the MFG's page or give us the .006" duration numbers? Then we can work your 8.5-1 DCR backwards and figure out what SCR would be required. Then we can look at the heads you are using, gasket thickness, bore, stroke and figure out what you will need in a piston to achieve your final DCR.
