Driven a 72
Heater Core question.
On the heater core does the top hose go into the intake and the bottom to the waterpump or is it vise versa. I have looked at several pictures and have seen them hooked up both ways. I live in Minnesota so it is gunna have to get hooked up if im gunna use her as a daily driver. Anywho thanks for any help.
1996 GMC JIMMY 1972 CHEVY C10 LWB My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729 |
I am a Referee of life.
Re: Heater Core question.
It works either way but one is 5/8 and the other is 3/4 so if they match.....I put my heater core in upside down because I didn't like the hoses crossing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Driven a 72
Thanks I kinda figured as much. But wouldnt the coolant be hotter coming out of the waterpump? Probly not but just thought I would ask since I live in mn and need it as hot as possible. Thanks again.
#4 | |
Sierra Grande Club
The trucks with automatic transmissions had the return line going directly to the top of the radiator from the heater core. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#5 | |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 03-30-2009 at 09:19 PM. |
Driven a 72
Yep sounds right to me thanks for the info as always. Never fails, got a question and it will be answered.
Cheers
#7 | |
Sierra Grande Club
s/t
Ok I have a related question. 72 automatice trans with A/C Heat always on. I have the vacumme controled valve in heater hose that is new but is not closing? But hot water is alway flowing I think through core. Is this wright??
Sierra Grande Club
You should be able to connect it to a known vacuum source and watch it close. If so then it’s up stream on the vacuum side especially since you said the valve is new.
s/t
