Old 04-01-2009, 01:19 AM   #1
Grapdawg
Driven a 72
Grapdawg's Avatar
Electrical Nightmare Please Help
Ive got a electrical nightmare, Ok so here are my symtoms.
Headlights on blinkers wont work at all.
Headlights off blinkers work but both rear blinkers blink.
Step on brakes with lights off and dash lights light up.
Any suggestions?
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 04-01-2009, 01:32 AM   #2
kwplot34
Re: Electrical Nightmare Please Help
Time to check all the grounds,and check all the wires for shorts, but i would make sure all the grounds are good first,bad grounding can cause some funny things to happen.
kwplot34 is offline   Reply With Quote
Old 04-01-2009, 01:39 AM   #3
mr48chev
mr48chev's Avatar
It does sound like a ground problem with the taillights.
One more thing to check that tends to cause problems on these trucks is a cobbled up trailer wire connection that someone put on at one time or another. Those can be a prime source of shorts and messed up connections if they were not done right.
Old 04-01-2009, 01:59 AM   #4
kwplot34
That is a very good point,and a good place to check. the wiring on these trucks is pretty simple, i also just remembered,make sure the ground strap from the engine block to the fire wall is connected,not a bad idea to take them off and clean them,or replace them.
Old 04-01-2009, 05:36 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i would start off with new bulbs and checking the grounds
Old 04-01-2009, 05:55 AM   #6
Grapdawg
Driven a 72
Grapdawg's Avatar
Thanks all I will post up some pics of the mess that is in the back. I think it may be a trailer light setup. Also does the engine have to be grounded to the firewall or can it be the frame?
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-01-2009, 01:11 PM   #7
soule64
soule64's Avatar
I had similar issues when installing a new Painless harness. Turned out to be ground issues. I grounded 4 places: engine-chasis, engine-frame, chasis-frame, bed-frame. All with braided straps, cleaneaned to bare metal and coated with dielectric grease. No problems now.
soule64 is offline   Reply With Quote
Old 04-01-2009, 01:19 PM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Sounds like the headlight switch has failed and you are getting electrical feedback through it once you turn your headlights on. Replace the switch and also check your grounds like everybody else says. I had a simeler problem on the Blazer that is in my shop now, but the new headlight switch solved it. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-01-2009, 02:16 PM   #9
Grapdawg
Driven a 72
Grapdawg's Avatar
Ok I have the Engine-Frame and Bed-Frame Were would I ground the Engine to Chasis and Chasis to frame. Im sure they are there somewere. This sucks. I think it may have to do with my turnsignal switch as well but not sure as it is very worn out. I did however replace the voltage reg and had my alternator tested. Found a bad ground to it but now that is resolved. So im stumped I guess I will go through all the grounds and see if I can find those other grounds. there were 3 black wires on the back of the truck that were just hanging there. My brake lights didnt work until i twisted them together. Thanks for all the great help as always.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-01-2009, 03:16 PM   #10
kwplot34
Yes you need ground straps from the frame to body and motor to body,or else the only ground path is through the body mounts and that is not a good ground path.
Old 04-02-2009, 09:04 AM   #11
soule64
soule64's Avatar
On mine, the engine-chasis was on the p/s cylinder head to a large machine screw on the firewall. The Chasis-frame strap went from the p/s fwd cab support to a hole in the top of the frame.
Old 04-02-2009, 03:17 PM   #12
soba_03
soba_03's Avatar
I agree, I had a problem exactally like you have. I too found that it was headlight switch. Over the years it got some corosion in there cleaned up the plug and switch and solved my problems. Unplug you headlight switch and look at the plug them grab a flash light and look at the light switch or pull it out and take a good look at it..
Good luck...
soba_03 is offline   Reply With Quote
