03-09-2003, 12:26 AM | #1 |
Crossover steering, what do I need?
I know a couple of you guys have done crossover steering(Pont, 6869704x4) what exactly do I need? Call me "tupid" but could you make like a shopping list for the items needed? It will be for a D44 on a '71 with 3.73's.
Thanks, Matthew
GOD is good...All the time! '71 swb custom10 barn find-68K original miles 72 K5 CST rust bucket, but runs and drives 84K miles |
03-09-2003, 05:49 AM | #2 |
No Brakes Club
mkmiller1,
I just started this project on some 3/4 Ton axles for my 85 GMC Suburban. I got alot of help from the guys on this forum. They sent me to www.partsmike.com He has everything you need. The total came out to less than $600 He is very knowlagable and friendly. Check him out.
Ryan Flowers 85 GMC Suburban 4x4 379 90 GMC Suburban 4x4 383 01 Chevy Suburban 2x4 350 Click here to email me Click here to visit my web site |
03-09-2003, 06:38 PM | #3 |
I need another Barley Pop
Mr. mkmiller1, I would be glad to help out. If your on a budget and don't wanna spend $600, there are more affordable ways to do the swap. It also helps to be in good with someone who welds and does metal fabrication. I'm into my crossover setup for about $150.
I'm just heading out the door and won't be back til late tonight but when I get in, I'll either send you a private message or post here all the parts you'll need and what all is involved. If you wanna read through the following post, I think I describe all the parts that I used to make my crossover setup. http://67-72chevytrucks.com/vboard/s...threadid=15383
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
03-09-2003, 07:44 PM | #4 |
I'll help too if I can.
The more I learn about women, the more I love my truck. |
03-09-2003, 09:33 PM | #5 |
Thanks for the replys folks!
I'm really not wanting to spend $600 bucks on the truck just yet(at least for crossover). I'll appreciate any info you can send my way, I've got a neighbor who is a welder by trade(we work out good deals-he tells me"Will weld for beer") and I'm pretty handy around the truck. Thanks for the "MR." Pont, but I'm only 21 with 9 years experience(i.e.30); you make me feel older.LOL Y'all can email me any info at mkmiller@magnolia-net.com and I love pics!!! This will only be a FUN truck with minimal FUNDS put into it hopefully. Thanks again, Matthew
03-10-2003, 12:59 AM | #6 |
Matthew (Mr. mkmiller1)
I sent you an email.........
03-10-2003, 08:29 AM | #7 |
No Brakes Club
Matthew,
Pont knows where to find better deals than me. I didn't shop around that much. Posted on the forum I was doing my lift and the cross over steering came up and partsmike's name came up a few times. I went with him because he had the complete kit. Pont, Hey man I still have another Suburban that I plan on doing the cross over to. Any info you could send that would save me money would be greatly appreciated. The kit includes all new parts: PMPs New casting tall knuckles Spicer ball joints with snap ring, cotter pin, nuts, adjuster Spindle studs and nuts PMPs *Custom flat arms or **Super arms High steer studs Cone washers Lock nuts Stop bolt and nut Kit with custom flat arms. Part # SP1101KK $699* Kit with super arms. Part # SP1102KK $739** Thanks,
03-10-2003, 08:34 AM | #8 |
No Brakes Club
Pont,
Also I am wanting to do the disc brake conversion to both burbans. Do you have any advice? Matthew, Good luck on the cross over steering. Post us some before and after pics when you are done. How big of a lift did you go with?
03-10-2003, 11:06 AM | #9 |
My parts list.
D44 axle with blown chunk. $50 (for axle shafts and disc knuckles) Machine work for right knuckle. $60 Steering arm and stud kit from Shakerbuilt $110(to my door) Drag link(1.25 tubing threaded for Chevy drag link ends) from Shakerbuilt $73(to my door) Pitman arm from 70s fullsize jeep(DONT USE THIS ONE) $10 4x2 steering box $25 I also bought new ball joints, tie-rod ends, and brakes. This cost more than the parts for the steering mod.
03-10-2003, 06:08 PM | #10 |
Ryan, I'm not sure I would be any help on the disc brake conversions. I simply took the old closed knuckle Dana 44 drum brake front axle out of my truck and put in an open knuckle Dana 44 disc brake front axle. The newer front axle came out of an 80 Blazer (I don't know if it was original or not) and it was a bolt in swap. As far as changing knuckles or spindles from drum to disc, I wouldn't have a clue. Sorry........
03-10-2003, 09:41 PM | #11 |
Bob Chayer 71 3/4 ton 4X4 Suburban |
03-10-2003, 09:45 PM | #12 |
Thanks for the help and advice so far.
Ryan-I'll post the pics when I start the process and somplete till finish. I've got the blazer drivetrain torn into a million pieces but will have it back together by weeks end. Then I'll start on the "jackup" as my 3 yr.old daughter calls it. It's only going to have a 4" lift(maybe a 2" body as well) and will just be a toy. 6869704x4-What all did the machine shop do on the right knuckle? I just want to know, if I have it done that way, what to expect of them on price for what they do. Pont-Thanks for the description and pics! My 5 yr. old son could figure it out with that description. Thanks again, Matthew
03-11-2003, 01:59 AM | #13 |
Pont:
First and foremost, I have always loved the look of your truck. Second, if you have the time and are cool with it, could you either post the info that you sent to Mr. mkmiller1 on the board or send it my way. I just made a deal for a 4x4 with another member and I have hopes and dreams for some modifications. Thanks.
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
03-11-2003, 10:35 AM | #14 |
mkmiller, He machined the top of the knuckle and drilled and tapped 3 holes. I took the Shakerbuilt steering arm and left knuckle in so he would have a reference.
Ryan, Swapping the whole axle is pretty easy. But if your doing new balljoints you have every thing apart anyway. My experience was on a 70 drum axle. To make everything fit right I had to swap from the knuckle on out. And I used the newer beefier axle shafts. The only parts I reused were my locking hubs.
03-11-2003, 11:06 AM | #15 |
GreenMystChevy, give me your email address and I will send you the same email I sent Matthew.
If anyone else is interested in this info, just post your email address and I'll be happy to pass it along. Rob Pont
03-11-2003, 11:58 AM | #16 |
No Brakes Club
03-11-2003, 12:10 PM | #17 |
Ryan, email has been sent.
Rob
03-11-2003, 12:21 PM | #18 |
03-11-2003, 12:34 PM | #19 |
Jeremy, email sent and thanks for the kind words on my truck. It's a project (well actually more like a money pit lately) that needs alot of work.
Rob
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" Last edited by Pont; 03-11-2003 at 12:36 PM. |
03-11-2003, 04:48 PM | #20 |
check out web site below. Two articles on cross-over steering one for Dana 44 the other for Dana 60.
http://www.off-road.com/chevy/tech.html |
03-11-2003, 08:13 PM | #21 |
Thats a good site. Whats cool about 1st gen trucks is that they are easier to do xover steering than the newer ones. No xmember issues.
03-14-2003, 11:42 AM | #22 |
Pesemistic Optimist
xover steering
This is a very informative link that I thought I'd throw out, should answer all your questions.
Dan. http://www.rightcoastcrawler.com/bil...ngresearch.htm |
03-17-2003, 12:10 AM | #23 |
Pont:
I was wondering if you could also send me the email containing the information on the crossover steering you did on your truck. I am nearing the completion of my truck and I know it is going to be a bugger to steer. Thanks, Evan wheel@tenforward.com
Evan Wheeler 75 Chevy: Short bed, mildy built 350, 8 inch Suspension lift, 3 inch body, 39 inch M/T Baja Belteds, and 15x12 American Racing wheels. |
03-17-2003, 02:41 AM | #24 | |
Simple and works well. No biggie. -- Mike
http://home.houston.rr.com/chevy73/ |
