1970 gmc dana 60 rear disc conversion
i thought i had everything to do a Dana 60 rear disc conversion. but it looks like i screwed up. i got a 3/4 ton front and pulled the discs and rotors to do a swap. the Dana 60 is totally different need what i read on line. the drums are held in place with two screws and the drums slide right off. any one know what disc i need to get. didn't see any that just slip right back on and use two screws to be held in place anywhere.
Resident of Here
Re: 1970 gmc dana 60 rear disc conversion
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
never mine i got it done
![]() Join Date: Oct 2007
Drbyrdman,
Mind sharing how you got it done? I need to do the same conversion. Thanks! |
took dana 44 rotors and install them on the rear. and i am getting some weld on brackets from ruff stuff to hold the calipers on.
Ok' where are the photos? So the rest of us can see what you did.
I've been tracking down pieces to use on my 71 but still need the caliper brackets. |
