so im nearing the stages of body filler and primer on my cab and front clip... i wanna know if i get the cab mounted and fenders on and everything primed.. if it is bad to drive the truck like that for a week... i just wanna be able to drive it a bit because i havent drove it in almost 5 months... then after a week start sanding primer and paint it... bad idea or what?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
![]() Join Date: Feb 2009
Re: opinions needed
no it will be fine to drive it as long as you want to i let my car sit for three years before i painted it and also drove it awhile too so you are good to go
Re: opinions needed
i just wanna drive it because if it sits like it has trans leaks from the speedo cable. so once i drive it it solves that problem... so thats why i asked.. thanks
