dazed and confused
cutting springs
i have an ece rear drop 6". i dont have the money to buy the spindles and such. has anyone ever cut a 3" front spring just enough to get the truck to level out?
members met: redbaron69, billsbowtie,nc67 |
resident oilfield trash
Re: cutting springs
Bad Idea. 3 inches is the most your control arms can handle.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Re: cutting springs
If you must cut the most you can cut is one coil other than that you need lowering spindles and srop springs.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
dazed and confused
Re: cutting springs
yea i was worried about alignment and if it would cause anything to bind.
Moderator
![]() Join Date: May 2007
Re: cutting springs
It will. Save your money and get dropped spindles and do it right.
dazed and confused
Re: cutting springs
thanks guys!! this site is alwys helpful!!!!!!
