Old 03-29-2009, 12:53 AM   #1
PHAT TONY
PHAT TONY's Avatar
Blazer Body Questions
I'm a new blazer guy; bought a '72 2wd a week ago with a clean 4wd tub. The 4wd isn't on a frame, and I'm replacing a slightly rusty right rocker and the lefty as well(exploratory). The doors are not fitted well and I've got the body on a dolly; I want to at least metal work it before it goes on the frame. How much can/will the a-pillar relax without the front clip on? I see when I close the 2wd doors that they move the w/s post as the roof has 3 bolts holding it to the rustiest tub ever, so I'm not very confident in measurements I can take. Do I just square the doors up to the quarters and body lines and let 'er fly? Anybody?
PHAT TONY is offline   Reply With Quote
Old 03-29-2009, 02:40 AM   #2
70 Suburban
Rods
Re: Blazer Body Questions
with out the top my advise is to square up the a piller to make to doors fit well. the start on your rockers. i welded a brace from the top of the windshield frame to the bi piller and another from the a to the b piller at the top of the door line then took the doors off
70 Suburban is offline   Reply With Quote
Old 03-29-2009, 03:21 PM   #3
teamradrz1
teamradrz1's Avatar
not sure of your skill level but I think the safer option would be to mount it on the frame before doing that work to ensure there is no twist when mounted. JMO
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 03-29-2009, 03:41 PM   #4
skidder111
skidder111's Avatar
It's a good idea to check the condition of the rocker boxes too. They are there to stiffen this area of the body. Scott's has replacements.
skidder111 is offline   Reply With Quote
Old 03-29-2009, 04:01 PM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I agree, I wouldn't do any cutting with it off the frame.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 03-29-2009, 05:35 PM   #6
PHAT TONY
PHAT TONY's Avatar
After some door adjusting, I think the firewall/cowl has relaxed forward a little. I don't know how this body was removed from the chassis or how long it's been bouncing around un-braced. The floors, rocker boxes, toe boards, cowl sides, windshield frame is all incredibly solid. Guess I should pick a color so as to paint the firewall and do a body swap first. I need a right door, I'm guessing I can cut a truck door's window frame.
Old 03-29-2009, 07:37 PM   #7
SOON2BLAZE
SOON2BLAZE's Avatar
Agreed, lots of flex in these tubs.
Save the pieces off of the blazer door for use on the truck door ( there's a post on here about it)
SOON2BLAZE is offline   Reply With Quote
Old 04-02-2009, 07:18 PM   #8
PHAT TONY
PHAT TONY's Avatar
After a better look; I think I'm good. Whataya all think?
Old 04-02-2009, 09:44 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looks really decent, Not much needed based on those pic's
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-03-2009, 08:14 PM   #10
Yukon Jack
Yukon Jack's Avatar
I know it's tempting to do the body work off the frame but you really should get it mounted to the frame, get the front clip installed and the top if possible before you start. Lot of work I know, but when you do the repairs and put it on the frame and find things aren't right, it's gonna be alot more work.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
