Re: voltage regulator
would it be possible to retrofit the newer one?
1972 Chevy C10 Long Bed 454 Big Block Turbo 400 3 Speed Dual Flowmaster Edelbrock 750 Carb Power Steering Disc front brakes Drum rear brakes B&M Floor Shifter |
Active Member
![]() Join Date: Jul 2007
I think the only difference is that most of the new ones are solid state. At least the replacement I got for my GMC was. Doesn't matter if you have gauges or lamps.
They're made to regulate the voltage depending on vehicle's needs to keep it at constant level. Old style had mechanical relays to regulate voltage and new ones have transistors. |
