Old 04-04-2009, 01:43 PM   #1
texastrendz
brake hose too short with air suspension
i was wondering what brake hose you all are running on the front with air suspension, i installed my drop spindles and bags on my 72 chevy and when the suspension is compressed my brake hoses are too short. Any help would be great. thanks.
texastrendz is offline   Reply With Quote
Old 04-04-2009, 01:44 PM   #2
XXL
Señor Member
XXL's Avatar
Re: brake hose to short with air suspension
'73+ on the front side, IIRC.
XXL is offline   Reply With Quote
Old 04-04-2009, 04:52 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I saw this with my blazer also.
like XXL said the 73-87 hoses are much longer. I decided to go the stainless braided route, using 3 AN fittings on each end.
Keith
Convert to disc brakes.
Old 04-04-2009, 09:18 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
S/S braided lines to the length needed.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-04-2009, 11:22 PM   #5
texastrendz
73+ lines will not work, not right on the brake line side, i just cut off my mounts and moved them up and out a little bit and welded them back on. works great. thanks.
Old 04-07-2009, 07:47 PM   #6
AJohn6
Knuckle head
AJohn6's Avatar
i had the same problem. Runnin S/S braided lines now. i will try and find out who makes them for ya.
Adam
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 04-07-2009, 07:58 PM   #7
AJohn6
Knuckle head
AJohn6's Avatar
OK, can't figure out how to edit last post. I found the brake lines I am using. I ordered them from earlyclassic.com.
Part# 03-CT1002, Description- 71-72, braided stainless steel, set, $125
Adam
Old 02-08-2016, 05:07 PM   #8
jondancer
Is this common? Or only if the drop is extreme like laying frame?
jondancer is offline   Reply With Quote
Old 02-09-2016, 12:30 PM   #9
blazer2007
are 4x4 lines longer ?
blazer2007 is offline   Reply With Quote
