brake hose too short with air suspension
i was wondering what brake hose you all are running on the front with air suspension, i installed my drop spindles and bags on my 72 chevy and when the suspension is compressed my brake hoses are too short. Any help would be great. thanks.
Señor Member
Re: brake hose to short with air suspension
'73+ on the front side, IIRC.
67-72 parts collector,…
![]() Join Date: Nov 2002
I saw this with my blazer also.
like XXL said the 73-87 hoses are much longer. I decided to go the stainless braided route, using 3 AN fittings on each end.
GM ONLY BABY!!!
S/S braided lines to the length needed.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
73+ lines will not work, not right on the brake line side, i just cut off my mounts and moved them up and out a little bit and welded them back on. works great. thanks.
Knuckle head
i had the same problem. Runnin S/S braided lines now. i will try and find out who makes them for ya.
Adam
Adam '71 SWB/Step ![]() 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. ![]() |
Knuckle head
OK, can't figure out how to edit last post. I found the brake lines I am using. I ordered them from earlyclassic.com.
Part# 03-CT1002, Description- 71-72, braided stainless steel, set, $125
Is this common? Or only if the drop is extreme like laying frame?
are 4x4 lines longer ?
