Old 04-04-2009, 07:39 PM   #1
69ChevyRazorback
Do i need the kick down hooked up on my carb?
when i bought my truck, the throttle cable was not connected to the kick down on the carb. i tried hooking it up, and it wasn't adjusted properly, and I smelled alot of gas like I was flooding it so I just unhooked it and left it like it was. Is there any advantages or disadvantages to having it hooked up? should i leave it un hooked or try to properly adjust it and connect it?
69ChevyRazorback is offline   Reply With Quote
Old 04-04-2009, 07:50 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Do i need the kick down hooked up on my carb?
You can manually downshift it so you dont need it hooked up. Basically all it does it downshifts it for you when you stomp on it. Some of the aftermarket rebuilt trans dont even have a kickdown hookup its blanked off.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 04-04-2009, 07:55 PM   #3
pat123
Pat
pat123's Avatar
its good to have just encase u have to make a quick getaway lol faster to stomp it then manually shift down.
pat123 is offline   Reply With Quote
Old 04-04-2009, 08:37 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is a Th350, then no, not really. It'll shorten the life a little, but not much.
If it is an overdrive, stop driving it now. They will die with only 10,000 miles if misadjusted... let alone removed all together.
Old 04-05-2009, 01:33 AM   #5
69ChevyRazorback
no sir, its just a 350 trans, no overdrive......
Old 04-05-2009, 09:30 AM   #6
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
It has no effect on the carb tuning.
MT71c-10 is offline   Reply With Quote
Old 04-05-2009, 09:56 AM   #7
Ram-Man
Ram-Man's Avatar
Good point I jumped to the assumption that it was a th350. We all know what happens when we assume.
Old 04-05-2009, 11:13 AM   #8
old Chevy guy
old Chevy guy's Avatar
While its true that it won't affect the tuning if its out of adjustment and puts presure on the throtle plate and also the accelerater pump,it could cause it to flood or weep fuel. Another note if I remember right on a TH 350 when you manualy put it in 2nd it drives on the band instead of the drum and causes premature wear.I could be wrong. I worked at a transmision shop 19 or 20 years ago and even then I was only the installer.Not as hard as building them thats for sure,I took hundreds of those things apart for my boss but couldnt put one back together.Anyway thats what I think he told me once about 2nd gear,probably no big deal anyway if your not doing it every 5 minutes.
old Chevy guy is offline   Reply With Quote
Old 04-05-2009, 11:49 AM   #9
Sinister
Between Trucks...
Sinister's Avatar
The kickdown is half the fun of driving an auto in these trucks, IMHO.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-05-2009, 07:40 PM   #10
69ChevyRazorback
ya i guess i just need to play with the adjustment on the throttle cable until i get it right.
