Young gun
sway bar brackets
when using airbags are you supposed to use stock or lowered brackets? thanks
Nothing to see here.....
![]() Join Date: Jun 2007
Re: sway bar brackets
you can either run the dropped brackets or mount directly to the frame.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Tot Roddin'
I've even seem some people use the stock brackets and then mount the bushings on the inside of the bracket. If it were me I would pick up a set of lowered brackets and run those. And if you didn't want to do that, then I would mount the bushings directly to the frame.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
