Old 04-09-2009, 01:54 AM   #1
72blue
72blue's Avatar
thorley headers on a 67-72 sbc
Is anyone running these on angle plug heads? I am running a set of canfield's and when I bought the headers they said "fit most angle plug heads." That being said, I know I am not the only sap that chose angle plug heads of some sort and thorley headers...I hope. Anyway, the #5 plug is problematic; close to the header tube and I was thinking of the "shorty plugs" and not sure just exactly how much shorter they really are. Accel says (and I an awaiting them to answer my question as to how much shorter their plug that compares to the autolite 3924 canfield recommends really is) their shorty plugs are 3/16" to 3/8" shorter than the plugs that the shortys replace. So if anyone is in the same boat as I, what did you do? I am entertaining the idea of putting my ram horns back on if I cannot keep from frying a plug wire every few weeks or so.
Thanks to all
James
James
72blue is offline   Reply With Quote
Old 04-09-2009, 07:58 AM   #2
Jim_PA
Re: thorley headers on a 67-72 sbc
You'll love those headers - No angle plugs here though.
Jim_PA is offline   Reply With Quote
Old 04-09-2009, 12:43 PM   #3
72blue
72blue's Avatar
How long have you had yours Jim PA? Are they coated? How well is the coating holding up?
James
Old 04-09-2009, 12:48 PM   #4
Jim_PA
I've had mine almost a year and a half. I got the cheap coating... I think it's chrome or nickel???
They are discoloring (turning blueish/black) but not rusting anywhere. Looks kinda cool I think.
Old 04-09-2009, 12:51 PM   #5
big_al_71
big_al_71's Avatar
I have a small block with doug thorley headers and I had the same issue I bought the accel shortie plugs and problem solved...look at the pict below...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-09-2009, 12:59 PM   #6
Jim_PA
Yeah, but it looks like those are straight plug heads. What problems did you have? I used regular plugs on mine but I also have non-angle plug heads.
Old 04-09-2009, 01:18 PM   #7
big_al_71
big_al_71's Avatar
on the second picture the second plug with a reg size plg the wire was against the header and also plug #3 on the same side..I did forget to mention that I have straight angle edelbrock aluminum heads....Those two plugs were the only ones that I had the issues with.
check out this thread from when I had the problem...
http://www.67-72chevytrucks.com/vboa...d.php?t=306443
Old 04-09-2009, 01:23 PM   #8
Jim_PA
I see -- must be the big MSD boots, b/c I have the edelbrock straight heads too, and didn't have clearance problems.
Old 04-09-2009, 01:45 PM   #9
big_al_71
big_al_71's Avatar
what wires did you use?
Old 04-09-2009, 01:50 PM   #10
Jim_PA
Taylor Spiro-pro's
