Old 04-08-2009, 04:08 PM   #1
bravo
bravo's Avatar
chassis build
Anybody here build their own frame? I'm tempted to build my own. I want to use 2x3 tubing. I just don't know what thickness? Any tips or advice please..thanks in advance....
bravo is offline   Reply With Quote
Old 04-08-2009, 04:40 PM   #2
bentfab
bentfab's Avatar
Re: chasis build
here's the begging of our in house chassis. The front half will be coming together in the next few weeks.
bentfab is offline   Reply With Quote
Old 04-08-2009, 06:38 PM   #3
newagecustom
c10 Chop Artist
newagecustom's Avatar
Re: chasis build
I build my own frames, some pics.
newagecustom is offline   Reply With Quote
Old 04-09-2009, 12:20 AM   #4
Twisted Minis
Twisted Minis's Avatar
Re: chassis build
With a fullsize truck I would probably run 2x4. You can get away with a .120 wall frame. 2x3 is just too small, and you don't need that kind of room under a fullsize cab.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 04-09-2009, 12:45 AM   #5
abadsvt
abadsvt's Avatar
Re: chassis build
I also agree with twisted! 2x4 .120. I have a bunch of pics of my builds in the links below. They both have custom built frames. Depending on where you mount your cab mounts you will have over 1" of clearance from the bottom of the rockers with 2x4 tubing.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 04-09-2009, 12:52 AM   #6
newagecustom
c10 Chop Artist
Re: chassis build
All the c10 frames i have done are all 2x4 .120 wall incl the front and rear crossmembers.
Old 04-09-2009, 11:17 AM   #7
bravo
bravo's Avatar
Re: chasis build
Thanks!!!! real nice
Old 04-09-2009, 11:18 AM   #8
bravo
bravo's Avatar
Re: chassis build
Josh
your work is amazing!!!! Thanks for all the info and pics...
Old 04-09-2009, 11:21 AM   #9
bravo
bravo's Avatar
Re: chassis build
I race my truck, so do I have to worry about flexing? I want to build my own frame to take weight off, that's the whole reason..
Old 04-09-2009, 11:54 AM   #10
newagecustom
c10 Chop Artist
Re: chassis build
I wouldn't think you would save any weight by building a new frame. By the time i finish one with all the crossmembers, etc its about the same or a little more than a stock frame.
Old 04-09-2009, 12:14 PM   #11
Twisted Minis
Re: chassis build
Absolutely you need to worry about flex. That needs to be taken into consideration in any frame build, race or not. It only becomes more critical in some applications.
You likely will not save any weight. You will probably add some if the frame is built right.
Old 04-09-2009, 03:26 PM   #12
bravo
bravo's Avatar
Re: chassis build
Thanks guys, I'll stick with my stock frame. I'll probably just box it in..again thanks......
Old 04-09-2009, 03:51 PM   #13
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: chassis build
build a chromemoly frame
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
