Old 04-09-2009, 05:48 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
putting drop blocks on and cant get the nut off the u bolt..
trying to undo the nut on the u bolt and cant turn it i wd40 torched leverage bar and it wont budge, wats next? hurry help thanks
John
1999 Toyota Tacoma 4x4
Old 04-09-2009, 05:51 PM   #2
MonteSS454
MonteSS454's Avatar
Re: putting drop blocks on and cant get the nut off the u bolt..
Cut it and get you some new u-bolts and nuts
MonteSS454 is offline   Reply With Quote
Old 04-09-2009, 05:54 PM   #3
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I agree
especially if you got it glowing hot and have changed the tensile strength on the bolt.
Also the old saying comes to mind
"Get a bigger hammer"
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 04-09-2009, 05:56 PM   #4
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Try the torch wrench
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 04-09-2009, 05:57 PM   #5
sjarrett71
sjarrett71's Avatar
nut splitter works good
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-09-2009, 06:04 PM   #6
GOPAPA
GOPAPA's Avatar
If you have the 1/2 inch bolts with 20 threads to the inch like mine then you torque them tight to 65 lbs..
So, to use them again means the threads have been stretched already once ,,like others suggested ,,best to get new U-bolts.
I did mine and this is the specs on what to torque them to..
If you are trying to just get by until you can put new ones in ,,I understand .. papa
GOPAPA is offline   Reply With Quote
Old 04-09-2009, 06:25 PM   #7
truckster
truckster's Avatar
When I had to get some off of a rear end at a wrecking yard I used a cheater bar and was able to snap the bolts. It takes a whole lot of torque, though.
truckster is offline   Reply With Quote
Old 04-09-2009, 06:36 PM   #8
oldblue1968chevy
well i dont wanna cut em
my u bolts are 5/8 thread 3" wide..kinda have to force em a wee bit over the axle i dont wanna cut the ones ive got really..but...idk
never thought of cuttin em yall are agressive minded lol
John
Old 04-09-2009, 06:43 PM   #9
chas350
Are you using a good breaker bar with a piece of pipe over it? that with heat should take care of it as long as the socket does not slip (nuts not rounded over) otherwise you must cut them.
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 04-09-2009, 06:44 PM   #10
cparman
sharp as a marble
a torch, and get the nuts red hot and hit them with a GOOD impact. Worked on my 69 when I replace the original control arms, and added 2" blocks last year. If the nuts are that stubborn, I agree with others that it is time for new ubolts.
cparman is offline   Reply With Quote
Old 04-09-2009, 06:44 PM   #11
oldblue1968chevy
wd 40 then torched for a few, then 3 ft breaker bar lol, still nothing
i bent the socket wrench extension before i moved the 40 y o nut lol
anything else than cut em
i told my gf who was wachin me bend it that im superstrong lol
skinny and 145lbs
John
Old 04-09-2009, 06:45 PM   #12
oldblue1968chevy
were do i cut them at on the U?
John
Old 04-09-2009, 07:36 PM   #13
truckster
truckster's Avatar
If you can cut anywhere on the top of the U you should be able to get both sides off. If you cut on the side, you might have to cut both sides.
Old 04-09-2009, 07:42 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Just for your info.WD-40 stands for "Water Dispersant fomula 40" so contrary to popular belief WD-40 is not a very good penetrating oil.PB Blaster,Kroil,or Knock er loose are much better.
Also,if you're adding drop blocks you probably need longer U bolts anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2009, 08:21 PM   #15
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
That nut is the one that was responsible for me snapping the yoke on an 18" 1/2 drive breaker bar. I'm sure there was a jack handle involved as well. I took the pieces back to Sears and got an all-time great comment from the counter guy: "Well, we don't see that happen very often."
Yeah, and I don't break 'em all that often either.
Kroil and big-a** cheater bar will take care of it.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 04-09-2009, 09:49 PM   #16
tcb-1
Nothing to see here.....
tcb-1's Avatar
cut precisely at the top of the axle. then you will be able to swivel the nut and off it goes.
a cutting wheel on a grinder is great for ths job. remember, it will make a pop when it's close to being cut through from the release of torque on the bolt itself.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-09-2009, 10:21 PM   #17
oldblue1968chevy
okay...looks like im cuttin u bolts tomorow!
then workin on the project truck some i guess
John
Old 04-10-2009, 07:06 PM   #18
big mike71
big mike71's Avatar
Every bolt I take off breaks whether I want it to not.
big mike71 is offline   Reply With Quote
Old 04-10-2009, 07:20 PM   #19
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I agree with every thing and wanted to reiterate the use of longer u bolts.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-10-2009, 07:32 PM   #20
70k52wd
Blaze-Air
70k52wd's Avatar
s/t
X2...cut them with a grinder and cut off wheel. 1/16 wheel works great.
70k52wd is offline   Reply With Quote
Old 04-12-2009, 10:48 AM   #21
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Thats a stinky situation. When I did mine, 1/2 of the u-bolt was rusted solid inside the trailing arm. Look at my thread, lots of good tips on getting rusted stuff loosened up.
http://www.67-72chevytrucks.com/vboa...d.php?t=318663
MT71c-10 is offline   Reply With Quote
