Sierra Grande Club
vacuum advance hose. Metal or rubber
I had a metal line and it's somewhat distorted. Can I use just a rubber hose until I bend one up? Anyone make one out of stainless steel?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: vacuum advance hose. Metal or rubber
I've always seen rubber vac advance lines.
Active Member
![]() Join Date: Jul 2007
I've used both rubber and metal. Couple of months ago I bought some coated metal tubing from Auto Zone and with a tube bender made one to replace the rubber hose. It just looked neater than the rubber and I could bend it to fit where I wanted it to go.
forgot to mention... this is on my six cylnder. Last edited by 68gmsee; 04-10-2009 at 08:58 PM. |
What?
Originally mine came with a metal line, connected with rubber tubing. It has since disapeared, and I am using all rubber tubing for it now.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Several companies make them from stainless or OEM material. YOu can bend one yourself unless you want the factory appearance. Classic tube and inline both offer them, but I think I remember you have problems with brake lines so you may have to shop around, but to my knowledge not many if any of the venders carry these.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 04-10-2009 at 09:18 PM. |
its all about the +6 inches
rubber is fine
Sierra Grande Club
Thanks! I might look into making a stainless one after my truck is running.
s/t
