Old 03-17-2003, 08:42 PM   #1
firemanchuck
FightingFire Saving Lives
Difference Between C-10 And K-10
I HAVE A 1972 C-10 SWB 4X4 FLEETSIDE. JUST GOT THE TRUCK RECENTLY SO I AM STILL LEARNING ALL OF THE PROPER TERMINOLOGY. I AM CURIOUS WHY SOME FOLKS CALL THERE TRUCK A K10 AND OTHER A C10 WHILE THEY ARE BOTH 4X4'S. MY VIN STARTS WITH THE LETTERS CK, AND I HAVE LOOKED IT UP , IT WAS MADE IN ST. LOUIS AND IS A FACTORY 4X4. JUST CURIOUS WHAT THE DIFFERENCE MIGHT BE IN THE K SERIES AND C SERIES.
I KNOW THAT THE BLAZERS ARE K SERIES, JUST WASN'T SURE.
THANKS FOR YOUR ADVICE OR COMMENTS.
FIREMANCHUCK
firemanchuck is offline   Reply With Quote
Old 03-17-2003, 09:22 PM   #2
racedvl
racedvl's Avatar
C= 2x4
K= 4x4
racedvl is offline   Reply With Quote
Old 03-17-2003, 09:32 PM   #3
1972chevy4x4
1972chevy4x4's Avatar
That is true, a c-10 is a 1/2 ton 2wd while a k-10 is a 1/2 4x4. Check your vin on door or door post, if v8 4x4 cke and if inline 6 cks are first three letters. Same for 2wd cce for v8 and ccs for inline six. Hooe this helps and hope you find the K in the vin.
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 03-18-2003, 12:18 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The catch is, even the 2 wheel drive blazers got K/5 badging.
The first C in the 72 Vin denotes Chevrolet. You probably notced most VIN decoders do not reflect this.
Old 03-18-2003, 12:50 AM   #5
Hutch
Hutch's Avatar
Post the vin and someone can decipher it for you.
There are a lot of converted trucks out there.
If there is a K in the first of you vin then it is probably original.
Here is a 67 vin
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-18-2003, 10:04 AM   #6
ckhd
ckhd's Avatar
It's basically because only the Blazer had a "k" emblem. The non-cst/custom pickups had a c/10, c/20, c/30 badge regardless of wether or not they were 4-wheel drive. People either don't know or get confused.
It's like racedvl said, c=2 wheel drive, K=four wheel drive. Period. There is no such thing as a c10 four wheel drive, and there is no such thing as a K10 two wheel drive. It's also a nice 'red flag' to look for when you are buying one. If it's a 4 wheel drive and the vin is CEwhatever (or CCEwhatever for '72), then you know instantly that something has been changed (like the cab, or vin, or someone attempted a 4 wheel drive conversion).
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-18-2003, 11:48 AM   #7
firemanchuck
my win number
my vin is CKE142S190912
1972 CUSTOM-10 4X4 SWB 4-SPEED, DOES THIS SOUND RIGHT..THANKS FOR THE HELP.
Old 03-18-2003, 12:04 PM   #8
ckhd
ckhd's Avatar
C= Chevrolet (this first C started in '72)
K=4 wheel drive
E=8 cylinder
1= 1/2 ton
4= pickup
2=1972
S = Made at the St Louis, MO plant
1= a number all the plants used in this spot in '72
90912 = 90,912th vehicle made at this plant
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 03-18-2003, 12:21 PM   #9
firemanchuck
THANKS
THANKS GUYS, JUST WANTED TO MAKE SURE MY TRUCK IS WHAT IT IS SUPPOSED TO BE...CHUCK
Old 03-18-2003, 12:46 PM   #10
ckhd
ckhd's Avatar
If you want to make sure it's an original short bed, look at the model code in the glovebox. It should be KE10734. That means:
K=4 wheel drive
E=Eight Cyl
10 = 1/2 ton
7 = short bed
34 = fleetside pickup
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 03-18-2003, 01:03 PM   #11
firemanchuck
GLOVEBOX DOOR
THAT IS THE MODEL CODE IN THE GLOVE BOX.
THANKS FOR YOUR HELP. JUST WANTED TO MAKE ABSOLUTELY SURE. THANKS FOR YOUR TIME.
CHUCK
