Junior Member
![]() Join Date: Oct 2005
Adding weight for traction
Has anyone here added weight to the rear of the frame of your truck? I was trying to get some ideas before I start putting my truck back together.
1970 C-10 Fleet Side Gen IV 6.0 with 4L80E |
All you need is a set of slicks on these trucks,and they work, you can tune it with shock relocaters and pinion shims , other than that i will leave,,, good luck vince
Between Trucks...
Re: Adding weight for traction
You could move the fuel tank to under the bed.
Beat it to fit, Paint it to match... ![]() |
Active Member
![]() Join Date: Jul 2007
Depends on what you're going to do.... If you just want to increase traction for normal driving, then the above recommendations are what I would do. If you want traction because of weather conditions, the old sandbags are your best bet.
However, if you want weight/traction for racing, that's a totally different thing and would require some bucks. Stacey David of Gearztv show had a good one recently where he fixed up an old (I think 68-69) Dodge truck for better traction and less bouncing when racing. Might want to check out his site to see if you can find it or shoot him a note. http://www.staceydavid.com/index.php?content=home |
J'ville Junkman
![]() Join Date: Mar 2006
One of my buddies dad always put a 4x8 sheet of steel back there, been too long to tell you how thick it was.
72 3/4t Suburban 402BB (Daily driver for 8 years) ![]() 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) ![]() 53 Willys M38 |
I wouldnt do it every 100 pounds you lose a .10 of a sec in the quarter!!! On average!!!
Ernie
1968 GMC Rebuilding Stage ![]() 2001 Camaro SS SOLD ![]() |
