O2 sensor bungs for fuel injection?
I've got rams horn exhaust manifolds and really need a new exhaust system, from manifolds back. Its rusting through in too many places.
If I keep my truck much longer I'm putting in an FI system, sick of cold starts. Can I have the muffler/pipe company weld bungs into the collectors or just down from them? The bungs don't have to be right in the exhaust manifolds do they? Thanks very much.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current) past rides were: '70 Chev 2wd farm truck '71 GMC 2wd 1/2T 402 nice! '72 Chev 2wd 1/2T 396 '72 GMC 3/4T 4x4 2500 Super Custom suburban. Bozeman, Montana |
"Ochre Ogre"
You are correct, they are not in the manifold. There is a general location where they have to go however. They need to reach a certain operating temperature to function. It should be pretty easy to find that info. It will be something like 12 to 18 inches down the exhaust pipe.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Old member
Mine are in the manifolds. I was told to get it as close to the heat as possible, thats why the newer cars have heated ones now. It will run better the closer you get it to the source. Andy
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Goodbye Darlin'
My ACCEL/DFI came with a threaded nut to weld to the header. They recommend welding it on down at the collector. This is assuming a heated O2 sensor...
1971 Blazer CST SOLD! |
