Old 04-12-2009, 07:22 PM   #1
Skirkpat
Skirkpat's Avatar
Another one followed me home?
I found a parts truck for the '69...but there aren't alot of parts left on it. This guy tells me that it is nice, alot of good parts, so I drive 2 1/2 hours to find this? Kind of p'd me off. The good news is that I got to try out my tow bar that I made a few months ago. Worked pretty good IMO..
Skirkpat is offline   Reply With Quote
Old 04-12-2009, 07:25 PM   #2
Skirkpat
Skirkpat's Avatar
Re: Another one followed me home?
Tow bar worked great!!!
Old 04-12-2009, 08:12 PM   #3
BADSAM
J'ville Junkman
BADSAM's Avatar
Cool!
72 3/4t Suburban 402BB (Daily driver for 8 years)
68 GTO (never ending proj)
91 Kawasaki ZX-7R
57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans)
73 Corvette (17 yr old daughter's: Another project - what's wrong with me?)
53 Willys M38
BADSAM is offline   Reply With Quote
Old 04-12-2009, 10:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tow bard are ggreat! The only possible issue I see with yours, having it mounted up so far behind the bumper, of you go through a seriouse hump in an intersection, or a driveway maybe, the bar can come in contact with the bumper, and which ever is weaker will be damaged... or even both be damaged. Damaged tow bars can lead to a bad day.
So the douche bag said that thing was pretty nice? It isn't junk, but that's not what I'd call pretty nice. Did you get a good deal on it at least? What all is there worth having? Whats the plans with it?
Old 04-12-2009, 11:31 PM   #5
Skirkpat
Skirkpat's Avatar
I was worried about it binding there also but I can lift it about 4 feet off the ground installed wich gives me plenty of travel (I hope). I built it after I looked at 300.00 ones that did not look half as sturdy as mine. I overbuilt it by the towbar standards on the market that I saw.
As far as the deal, I think it was fair, $150.00 (originally wanted 600) I figured the frame was worth that, even though the knothead bent the rear horn pulling it out of the field for me. The frame is what I really wanted so I could detail it, and start ground up without putting the '69 out of commision this summer, by the time the frame is done and my engine is out of hock at the machine shop it will be winter and I can swap the bodys over.
last week I threw an old 4 bolt 350 together and put a 700r4 in it to get me mobile before my new engine is done later this month.
Old 04-12-2009, 11:35 PM   #6
Longhorn Man
kewl!
you do know the rear very most part of the burb frame isn't the same as the pick up frame?
Old 04-12-2009, 11:57 PM   #7
Skirkpat
Skirkpat's Avatar
Yes I know, it is not really trashed, he just bent the lower "lip" where he wraped the chain, it is still straight, I think I can heat it up an straighten it out, I will look it over a little better tommorow, but I think it will be an easy fix, just pissed me off since the frame was the main reason I drove that far...he said " the frame is perfect, just real minor surface rust, no wrecks"
The other bummer was that it was not power steering, I thought that most 72's had that? at least it has power brakes.
