Old 04-12-2009, 09:52 PM   #1
1968bigblock
super choke question?
Hello
Has anyone had experience with the "super Choke" aftermarket electric choke ? The Q-jet we put on our 72 Cheyenne had one but no info on the wiring. There is a red wire and a white wire coming out of the temp sensor that bolts to the intake. Does anyone know where they are hooked up? Thanks!
1968bigblock is offline   Reply With Quote
Old 04-12-2009, 11:10 PM   #2
Shane
Shane's Avatar
Re: super choke question?
What exactly makes it "super" ...
Shane is offline   Reply With Quote
Old 04-12-2009, 11:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm with shane... never heard of such a thing.
Do you have any photos of all this?
Old 04-12-2009, 11:16 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
It's for really cold areas
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-13-2009, 01:04 PM   #5
1968bigblock
Here is a pic .There is an electric coil that replaces the original choke and a temp sensor that bolts to the intake manifold. Out of the sensor there is a red wire and a white wire. I know one of them must be energized with the key,but I'm not sure about the other one. There is a "super choke" brand on the choke. Any help would be greatly appreciated. Thanks
Old 04-13-2009, 04:29 PM   #6
project 67 sub
project 67 sub's Avatar
the white/or black in some cases, wire should be your ground wire(you can attach it to your carb bolt/stud) and the red wire is your keyed ignition power wire.
this is the same way that i wired up the electric choke on my edelbrock carb and it works just fine. hope that i was of any help, and i hope you get your choke situation resolved
project 67 sub is offline   Reply With Quote
