Old 04-13-2009, 07:19 PM   #1
rex01atv
Anybody running 20x12 rear wheels on 67-72?
Just curious if anybody is running 20x12 rear wheels? Pics of these would be great. How much back spacing was allowed? Did you have to narrow rearend and install mini tub?
rex01atv is offline   Reply With Quote
Old 04-13-2009, 08:18 PM   #2
jkade
jkade's Avatar
Re: Anybody running 20x12 rear wheels on 67-72?
I have set my rear suspension up to run a 335/30/20 on a 20x12. I think I had my rear end narrowed to 53" and yes tou will have to mini tube is you are going to run a tire as big as me.
A 295/40/20 is about as big as you want to go with stock tubs in my opinion.
jkade is offline   Reply With Quote
Old 04-13-2009, 08:44 PM   #3
SCOTI
SCOTI's Avatar
The deeper the 'dish' you want, the less back-spacing you need. The less back-spacing you need, the more the rear-end needs to be shortened.
A stock width 67-69 12-bolt truck housing will work w/a 12" wheel w/about 7" of back-spacing. That's roughly a little more dish (or lip) than a stock 15x8" GM truck ralley. I plan to run 20x12's w/6" back-spacing so I'll be swapping in a housing that's 2" shorter than a 67-69 housing.
As Jkade mentioned, mini-tubs are mandatory if your truck is low (tucking the wheels/tires).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-13-2009, 09:11 PM   #4
Bowtie468
Bowtie468's Avatar
I'm running 20x12's w/ 4" backspacing in the rear. Total width, outside to outside of disc, is 55 inches. Sorry i'm unable to get pics as my rearend just came back from the powdercoater.
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 04-13-2009, 09:11 PM   #5
Painter D
Painter D's Avatar
What SCOTI said.
One day I'm going to get my 20x12's.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 04-13-2009, 09:43 PM   #6
rex01atv
Thanks so much!
Old 04-13-2009, 11:18 PM   #7
SCOTI
SCOTI's Avatar
I just came in from the shop & re-read what I wrote earlier while waiting for my welds to cool. I wanted to clarify that the housing I plan to use will be 2" shorter per side, so 4" overall.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
