04-02-2009, 09:11 PM | #26 |
Eat My Rust
Re: best way to increase top end speed in a 1967 K20
Reasons I don't speed
1) Bad front shocks, small bumps can get big. Never mount nitro shocks shaft down again.... 2) Inaccurate Speedo, I don't know how fast I'm really going. I just know 100 is roughly 70 mph and that's all I normally do. Unless I turn on the GPS 3) No tach, if I choose to speed in third, I'd have no idea how fast she's spinning. Though, I can listen to it. 4) Gas money 5) A loud, bright orange truck, does tend to get attention enough at 65. A big orange truck with the engine running hard, gets even more. The police would love me. |
04-02-2009, 09:35 PM | #27 |
I have the same problem I have a 72 GMC with that Bulldog of a tranny (SM465) and 410 rear end and the truck screams at 70mph thinking of going with an NV4500. How big of a job is it?
04-02-2009, 11:03 PM | #28 |
Future TOTM Winner
Pretty big, huge in my opinion if you are putting it in a 4x4, even BIGGER if you intend to mate it to your original transfercase. Damn cool if you can afford it and pull it off.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
04-03-2009, 12:09 PM | #29 |
im running a 400 on SM465 with 4.10's on 31" rubber.
I dont get anywhere fast, but on the bright side it gives people a better look at what a real truck looks like I am changing up to a 700r4 and 35" rubber tho, which "should" drop me to about 1600ish rpm hiway speed. Which is just perfect for cruzing to the car shows |
04-03-2009, 04:13 PM | #30 |
I'm surprised nobody mentioned these guys yet. http://www.gearvendors.com/index.html
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
04-04-2009, 08:03 PM | #31 |
Eat My Rust
I think an OD unit would drastically start moving things like the x-case, and its x-members around. Plus having to change drive shaft legths to compensate for it as well..
04-05-2009, 01:36 AM | #32 |
a 67 k20 would have an eaton rear, 4.10 is the highest gear set offered in the eaton and most 67K 20 trucks would of had 456's especially the 6 cylinders.
04-05-2009, 01:37 AM | #33 | |
The commercial unit would be the stronger of the two units that they sell. That was what I found out, when I researched them and spoke to their reps about 4 years ago. On a bright side, if you can find a newer wrecked or burned up Motorhome, it might have a gearvendors overdrive unit. What cool about these ODs, is that a 3 speed becomes a 6 speed.
'72 GMC custom camper 350/350 |
04-05-2009, 11:07 AM | #34 |
My DD 85 K20 has a 250 with a SM465/208 combo with 4.10's and 235/85r16 tires which are 31.5 inches tall I run at 3100rpm at 70 mph.
04-13-2009, 02:34 PM | #35 |
http://www.snoman.com/HTML/axlecalc_5a.html
give that link a try to help get ya a little closer to what your looking for |
04-13-2009, 07:23 PM | #36 |
i like that you want to go pass the 100 in a old 4x4 thats my goal too. But different gears or a overdrive should get you a little faster i belive. how do out what your top speed should be.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 04-13-2009 at 07:24 PM. |
04-13-2009, 09:05 PM | #37 |
Aluminum slot wheels rule...
I had my needle buried a time or two with 4.56 gears, and a time or two with 4.10 gears. Surprising, the truck was really stable at those speeds. But I won't do it again anytime soon.
04-13-2009, 10:09 PM | #38 |
nice thats my plans for my 350/th350 with 4.10s if it doesnt blow up.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
